John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,581
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I got a thing here that I'm not sure is worth mentioning or not. Hopefully it will benefit someone, maybe you guys that are just starting to pull wood with your tractors. Anyway, I cut a small hitch that was made up of bent over trees so they were arch shaped. The iron wood (hophornbeam) tree on the top hooked way out and around to the right so that it was sticking out to the side at right angles to the rest of the hitch. Something like that can be a real problem. Often when a tree like that hits something solid or goes thru a narrow spot it will get pulled out of the hitch, or try to push the rear of your tractor around as it levers against the rest of the hitch, or the worst case scenario is hooking something tall and dead pulling it down on top of you from behind. So you shouldn't just leave it unless you are in a field. You could just cut it off or easier, cut it part way through so that it folds back when it meets some resistance like you can see happened in this hitch. You can do the same thing if you are pulling out tops with wide splayed forks. Cut partially thru one side of the fork so it folds back into a more compressed form. You save on setting chokers, get more in a hitch, and they are easier to pull.
I use that partial cut technique sometimes when I'm winching out a tree that I've left a bunch of spreading limbs on. A few cuts in the right paces, and they all collapse against the trunk, making it easier to pull it out without hanging up (and avoiding having to go back for multiple trips pulling out the limbs separately).
