Price Check Kubota L3560 Open Station
   / Kubota L3560 Open Station #61
Its suprising how big of truck & trailer you end up needing to properly haul a not terribly big tractor.
   / Kubota L3560 Open Station #62
It's more than just a "nicer layout". HST+ is the big selling point, as well as other options that are standard with the grand L. The extra 700 lbs and 2hp are nothing to scoff at either. Bigger loader, telescopic lower links, Auto Throttle Advance, H-DS, more legroom, better seat, tilt steering wheel, electric pto switch, nicer hst pedal, throttle up button...that's pretty much all the things that convinced me to spend the extra for the nicer machine. I just fit better on a L3560 than I did a L3901.
Those are nice additions but for me it wouldn't be necessary.
If I was going to spend $5k more I would have upgraded to the MX4800 which is a step up in cylinders (4), 11 hp increase and 300 lbs more in weight than the L3560.
   / Kubota L3560 Open Station #63
Maybe you didn’t appreciate the difference but nevertheless it’s a lot more difference than 700 pounds and 2 hp.
   / Kubota L3560 Open Station #64
I know I like my L3560HSTC. I have found the cab to be great! During the summer months the air conditioning has been well worth the extra money. The HST+ is something I didn't know that I would like it, but use it all the time. It basically turns the tractor into a six range instead of a three range. I do most of my work in Medium and the HST+ allows me to adjust on the fly. So the cost difference between cab and no cab has been well worth it to me and the extra features (HST+, nice interior, Auto Throttle, Stall Guard, etc.) are all just icing on the cake.
   / Kubota L3560 Open Station #65
I think the cab would make it worthwhile. I just don't get the open station option for this model and spending the extra money for little performance gain.
Once I've thinned out my 40 acres of woods I'm probably going to look at the L4760HSTC but see if I can score a used one.
   / Kubota L3560 Open Station #66
R4. My dealer is the one who gave me the 30g per tire number. Whether or not it's valid, it's all I have to go on.
Thank you for sharing the Big Tex trailer weights. I must have misread some other information I previously found, but now I see you weren't too far off at all with your numbers. This indeed makes me more concerned that I may not be able to safely move my L3650 with loader/bucket, and a box blade with my current truck.
Tractor ~3500lb, loaded tires another 500lb, LA555 right at 1000lb, and L2256 is another 250lb. That with a ~3000lb trailer is 8250.
Box blade is another 400-500, depending on model (likely would get a 66-72" model).
My truck is rated at 6,900 GVWR, 15,975 GCWR, and max towing of 10,170. If I get a proper trailer around 3,000lb...I should be under limits with the weight of gear above.
6,900 GVWR + 8,250 for trailer/tractor...that's 15,150, which is 825lb under my GCWR, so I'd be legal. Definitely would want a weight distribution hitch and brakes on both axles. To be clear, my truck with passengers and gear is going to be significantly less than that 6,900 GVWR...but it's nice to go off that number. I'd say that's about 1k over what I'd really be for my actual truck weight.
I think you are right on the weights you list. My trailer with the L3560HSTC with loader, full fuel, and box blade weighed in right at 9,100. My truck is rated to tow 11,200 lbs. I have the trailer marked for proper placement of the tractor to ensure tongue weight. Also, where I tow is flat, as in biggest hills are overpasses on the highways, and pretty much at sea level.
Looks like there is a big difference in what 1/2 ton trucks are rated for depending on equipment. Also where you live and tow will make a big difference. If I lived where Fallon does I probably would not even consider towing the same rig with my truck, here it works fine.
   / Kubota L3560 Open Station #67
I'll 2nd that. Cabs arent good for all use cases or wallets. But that 2 speed HST+ is so worth it. Pretty sure you only get the normal HST on the MXes.
   / Kubota L3560 Open Station #68
Not intending to start a war here but, considering the models that you are considering, you might wish to look at the JD 2038R, if there is a decent JD dealer nearby.
I looked at one recently as a potential future replacement for my B3350, and was quite impressed.
You will likely find the JD a bit more expensive that either the Kubota or the Kioti. You will also likely be impressed by the features, both standard equipment and optional. It also makes about five more PTO HP than does the 3560.
SDT
Turns out that I was well off regarding JD 2038R pricing.
John Deere 2R Tractor Blowout Sale!! - farm & garden - by dealer - sale
Simply correcting misinformation. Nothing more.
SDT
SDT
Appreciate that. To be clear (mainly for any others that come visiting this thread in the future), the 2038R isn't directly comparable to the L3560.
2038R and L3560 both have the same/similar engine and PTO HP ratings, but the L3560 has a better hydraulic flow rate, physically larger and over 1k lb heavier. The L3560 is closer to a JD 4 series, but would be a small 4 series...something like a 4038, if that existed. From what I can tell, the 4044M is the smallest 4-series JD, which has about 300 lb on the L3560, and about 5 more HP, 3 more gpm flow rate on hydraulics, same 3pt lift capacity (~2500lb), 2in longer wheelbase (73 vs 71 of the L3560), and other differences.
Because looking at specs is kinda fun, the JD 2038R is more comparable to a Kubota L3901.
   / Kubota L3560 Open Station #70
Don't forget the bonus of having a plastic hood on the JD tractor
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2013 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A52707)
2013 CATERPILLAR...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A57880)
2005 INTERNATIONAL...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
UNUSED FUTURE 32" HYD MINI TILTING BUCKET (A57193)
UNUSED FUTURE 32"...
