Backhoe Jinma JW-03 backhoe manual desperately needed ASAP
   / Jinma JW-03 backhoe manual desperately needed ASAP #1
DickJuneau
Juneau, Alaska
Jinma 284
I desperately need the Jinma JW-03 backhoe manual, ASAP. It's for a circa 2006 JW-03 backhoe. Can anyone supply a link for downloading a copy, or can someone send me a pdf of the manual? I'll be happy to pay for one. Thanks! Dick Wood, Juneau, Alaska
   / Jinma JW-03 backhoe manual desperately needed ASAP #4
I have the original manual that came with my 2006 JW03. It is labeled operation & maintenance manual but it really is mostly a parts book.
If you have specific questions I can get the answers for you. Some of it is kind of hard to read but I will try to get is scanned and uploaded to my website.
Thanks! I'm racing the freezing ground here. Got 2 inches of snow today but the ground has not frozen yet. One issue is trying to hook up the pump. My son is working on that and wants to make sure he is hooking up the correct hoses. Here is a photo of our 2006 pump. He is also unsure whether the ports on either side should point up or sideways. HydraulicPump.jpg
   / Jinma JW-03 backhoe manual desperately needed ASAP #6
Well those adapters are quite different than mine. Just remember the larger one is the suction side. It should not matter which way the adapters point but I suspect the hoses will connect easier if they point down.
I have the manual scanned into a pdf file and uploaded to my web page. You can download it here:
Harnerfarm Jinma 284
The documentation file has some backhoe help tips at the very back of the document.
Hope this helps. Let us know if you have more questions.
   / Jinma JW-03 backhoe manual desperately needed ASAP #7
What Piper said.
You can configure the adapters any way you want to make it the easiest, just DO NOT switch them from side to side. My LW-06 had them facing to the rear. The hose from the reservoir connects to the large fitting.
Thanks everyone for the help. The manual helps a lot. By the way, does anyone know what happened to John Nelson? Did he quit the tractor business?
One more question I have. In the beginning of the video "How to Install A Jinma Backhoe" (by KenoTractors) I see a hydraulic line that has a filter on it. My setup has no filter on any of the hydraulic lines on the backhoe. Is this something that I need to get? Thanks.How to Install A Jinma Backhoe - YouTube
I don't see the backhoe help tips at the back. Those would be useful.
STORAGE FEES (A56129)
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Informational Lot - Shipping (A55315)
Informational Lot...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
