WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 12,475
- Location
- Philadelphia
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
One of the dreaded perennial topics, I’m sure... but with a twist I haven’t seen specifically addressed on TBN.
I have a new JD 3033R with 320R loader and 61” HD bucket, and it is mighty light in the rear. So light it easily spins tires trying to just get itself uphill or into my shed, even with the bucket empty, without engaging 4wd.
I have a ballast box from my old machine that I will use with this new machine, they both specify the same box and weight, although I also had iron wheel weights on my old machine. I’m trying to decide the best way to add ballast to the new machine, given the following:
1. 100% of the activity for which I use this machine has me driving somewhere across my lawn.
2. At least half the total use for this machine is directly lawn care, either spreading fertilizer and top dressing, spreading grass seed, harvesting walnuts off the lawn, or aerating.
The tires are R3 Turf, and the mechanics at my dealer seem to be under the impression that a filled turf tire won’t likely leave any impression on the lawn, and suggested I fill with Rim Guard. They said R4’s when filled will be **** on the lawn, but the turfs when filled stay as cushy as unfilled. I’ve heard a lot of conflicting opinions on this, and have trouble believing them on this, it seems to me any time you reduce air space in the tire you’re going to make it a lot stiffer at the same pressure.
Complicating this is the fact that the parts of my lawn where I do a lot of work in colder weather can be pretty soggy, I often bring water to the surface under the tires, even without ballast in the tires.
Has anyone here ever seen or run liquid ballast in their turf tires? How’s the effect on the lawn? What’s the effect on zooming around the lawn at speed with a hopper full of fertilizer on the back, when you have 700 lb. tires?
