Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #10,752
If my Timber Tuff sharpener ends up in the round file I might try this Oregon model, I have 0 interest in hand filing a 36" saw chain. This guy explains it pretty good, I didn't know about the 10* degree back tilt on a chain, wonder how many get 10* on hand filing..................... This one might also work for SC lumberer jacks especially the ones with swimming pools.
Oregon 41-12 Bench or Wall Mounted Saw Chain Grinder. 1 Year Review. (part 1 of 2) - YouTube
   / Tractors and wood! Show your pics #10,753
I only have one with a 24" bar, and then an 18, a 12, and a 10 inch on the stick... And I've not seen a pig in almost 2 months... I'm getting worried, I really need to put a couple in the freezer!! :yell:
Well what about my trophy for winning in the saw sharpening contest, :hissyfit: perhaps you have to many freezers....................
   / Tractors and wood! Show your pics #10,754
After looking at the resent Power Wagon pictures, I had to go look them up I remember driving one around the farm back 1972. If I remember right I dont think it had power steering, I sure would like to have it now, what is it about the 40s and 50s thats so appealing................ The History of the Power Wagon - YouTube
   / Tractors and wood! Show your pics #10,755
I don’t know exactly why, but I have to agree with John, this thing works great.
   / Tractors and wood! Show your pics #10,756
   / Tractors and wood! Show your pics #10,757
How bout some venison.... "if" you win
   / Tractors and wood! Show your pics #10,758
We were at a log bucking seminar and several of our contractors were talking. They said that there is no excuse for anybody using a dull saw with all of the guides there are available; and that's the one they recommended. These guys all have dozens of employees and started out back when wood was all cut with a chainsaw; so know what they are talking about. I have one of the above for each of my chain sizes.
Just don't put them on the wood stove, if you come in at the end of the day and need to melt the snow off it.
   / Tractors and wood! Show your pics #10,759
That's the one I use too. Simple and fast. I use the full chisel LGX73 saw chain. The top of each tooth has a file angle line etched on it. I use that as a file angle guide but the difference between that and the edge of the roller guide is so small that my eye can't really see it.
EDIT: John here is an interesting little diddy I found on FF.
" Howdy,
With a chisel tooth, if you set the vise angle at 30, and the vise tilt at 10, the net top plate angle will be about 25.
Regards
Gregg "
Hunt that meat ought to be the type that melts in your mouth. I can almost taste those back-straps looking at your picture.
Some of you guys have run over your chain saws. But how many of you have run over your helmet ?? I have a long story but the short version is stupidity. The saw wasn't running but it still should have been on my head. Nice almost new Husqvarna A-number-1 helmet too.
gg
   / Tractors and wood! Show your pics #10,760
You do realize that the guide is only for use with one size file - the size that is stamped on it, right? Using the other sizes on it will not give your chain the correct tooth profile. You have to get the matching guide for those size files.
With the right size file, and the proper technique, they do give very good results. The technique is a lot easier to learn and less prone to error than sharpening freehand. I use one of them regularly:
I also use one of the roller guides from time to time. I like it a lot, since it gives a better view of the tooth as you are sharpening. Two reasons don't use it more often: 1) it's set up to give a 30˚ angle on the cutting tooth. Since I mostly run full chisel chain, I generally sharpen at 25˚. It is possible to sharpen at 25˚, but there all of the visual guidance the tool provides is for 30˚. (Not a HUGE difference, but it is noticeable if you are paying close attention.) and 2) It's small enough that I'm more likely to lose it in the woods (I suffer from the "set a tool down and it ceases to exist" syndrome).
I prefer the depth gauge attached to the roller guide or one like shown below (when I'm using a sharpening tool like the first one shown). both result in a chain that is far less sensitive to having all the teeth exactly the same length.
The other good hand sharpening tool I've tried is the Pferd Chain Sharp CS-X (which they also make for Stihl, which sells them as the Stihl 2-in-1 filing guide). It's not my favorite, though it does do a good job. A couple of friend swear by it. It's big advantage is ease of use/learning, and it's fast, since it files the depth gauge at the same time as the cutting teeth.
So how does that roller unit keep the angle correct? Looks like the file could wander all over the place..
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
CATERPILLAR 279D3 SKID STEER (A52705)
CATERPILLAR 279D3...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
