Concrete base
   / Concrete base #1
JMER817
Grass Lake, Michigan
John Deere 4120
So prepping for my future Polebarn I had to cut down and remove a dozen or so trees. Had an excavator come out and rip out the stumps. I sifted thru with my box blade and brought in 100yards of bank run fill dirt. The depth of the fill dirt because of the slope ranges from 6” on one end and up to 30” on the other end. I spread it in 2-3 lifts using my Harley rake. My plan was to let it settle over the winter and let the freeze/thaw cycle do its thing. I figured this would be enough compaction before laying the concrete floor. Now I am beginning to second guess myself. Should I have compacted it in multiple layers with a plate compactor? Debating if I need to strip down and re-level but use the compactor. Thoughts? IMG_1312.jpgIMG_1313.jpgIMG_1314.jpg
   / Concrete base #2
Frost and rain are the best compactors you will get. By spring it will be fine. Are you going to put down foam board before pouring? Aside from the obvious insulating value it will also spread out the weight of the concrete, although I doubt that you would have a problem anyways. Just make sure that the frost is completely out before you start pouring, it can go down a long ways in gravel.
   / Concrete base #3
Plate compactors are horrible for compacting soil. They are more for compacting a few inches of base for patio pavers.
I would fill up the front bucket with a load of dirt and drive over the pad so my tires covered ever inch of it multiple times. Then I would do that again a few days after it rains. And depending on how hard the pad gets, I might do it again a month or two later after it rains.
   / Concrete base #4
What is bank run fill dirt? The pics show something with organics and maybe clay?
   / Concrete base
Mixture of small stones, sand, and a little clay. Everyone around me uses it for fill.
   / Concrete base
I see that I can rent 450lb plate compactor which states can compact up to 16”. If I decided to rent one this would be this larger unit. Most other compactors are around the 150lb range.
   / Concrete base #7
That should lay in fine. The footings for the poles would get into the native soil below. The flat work should be over a few inches of sand- I’d put the sand in right before I did the flat work.
I don’t think the imported soil will benefit from re-laying it in smaller lifts. Sand and small stone don’t get much tighter with added weight and or moisture.
   / Concrete base #8
If you did it in 2-3" lifts and then drove over each layer to compact it, I think you'll be fine. That's what I did for my barn 5 years ago (using a base of #3 gravel with layers of compactable sand/clay fill). Have not seen any settling issues at all.
   / Concrete base #9
With the amount of granular material your’e fill contains a small smooth drum vibratory would be ideal. The plate compactor also works. Both take a little time. Especially the plate compactor. As the clay content rises toothed compactors work better.
   / Concrete base #10
Definitely get roller or large plate compactor. Material will take years to self compact . Ideally material should be compacted in 6" lifts
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
Giyi 77" Sweeper (A53316)
Giyi 77" Sweeper...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
