Honda EU3000iS generator spark plug wrench
   / Honda EU3000iS generator spark plug wrench #1
mjw357
The Sticks, Ohio
Kubota B3200
   / Honda EU3000iS generator spark plug wrench #2
List NGK BPRS5K plug which is either 3/4 or 13/16. Not at home or could give exact as I have that plug for my push mower. May need a swivel drive to reach. Good luck. Will update when back at home base. Hope you had a Merry Christmas!
   / Honda EU3000iS generator spark plug wrench #3
You really aren't doing the generator any favors if this is simply for off season storage. Your motor oil is protecting the engine from corrosion, spark plugs should be replaced on schedule rather than being cleaned- plus excess oil just creates a messy, extended start.
   / Honda EU3000iS generator spark plug wrench #4
Well while that may be true what you say, it doesn't help the OP who is looking for info on how to get the spark plug out. Removing the plug to check on it's condition sounds like a good idea to me.
Sorry NJW, I don't have any help for your issue.
Richard
   / Honda EU3000iS generator spark plug wrench #6
Richard
Kudos to you Richard for finding a video. I know that if I had a genny to fire up on a cold winter's day, I'd much rather it not have a tablespoon of oil in the combustion chamber.
   / Honda EU3000iS generator spark plug wrench #7
MJW,
Were you able to remove and check your spark plug?
Richard
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2011 International ProStar T/A Day Cab Truck Tractor (A51692)
2011 International...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
2004 Lull 944E-42 Telehandler (A53117)
2004 Lull 944E-42...
