Plastic Gas containers and Plastic liners in Pickups?
   / Plastic Gas containers and Plastic liners in Pickups? #31
Diesel won’t ignite like that. Locally the truck station has hoses that are probably 20 feet. Everyone fills tanks in the back of their truck. How else are you going to fill a tank that holds 50 gallons or more?
In that case, I'm back with the "they're too cheap to buy a longer hose" theory.
   / Plastic Gas containers and Plastic liners in Pickups? #32
I've always set my five gallon plastic gas jugs on the ground to fill. The five gallon jerry cans stay in the bed of the pickup when I fill with diesel.
   / Plastic Gas containers and Plastic liners in Pickups? #33
I have a liner in my aluminum bed F150. My 50 gallon diesel tank sits on a wooden frame I can lift with my forks. I may not need it, but I will be making a grounding strap to connect the tank with the bed. Better safe than sorry.
BTW, I had a fuel station on my 5th wheel toy hauler. It had a grounding strap for fueling the UTV. Did not need a grounding strap when filling the tanks on the 5th wheel (generator or fuel station) as it was likely grounded through the 7 port plug.
That has me thinking....can I ground my diesel tank by plunging a line to the trailer hook up?
   / Plastic Gas containers and Plastic liners in Pickups? #34
Seems like I remember gasoline transport trucks that had a chain with a metal circular piece (like a wheel bearing) hanging from the rear frame of the truck. It dangled and hit the pavement as the truck traveled, making a clanging noise as it moved along. Must have
had something to do with this very same subject.
   / Plastic Gas containers and Plastic liners in Pickups? #35
Let's just hope it was something that didn't cause sparks.
I seem to remember ground straps/wires on some older cars or trucks.
   / Plastic Gas containers and Plastic liners in Pickups? #36
Grounding to the truck bed does not make sense to me. The tires act as insulators to ground. Static built up during fueling needs to go to the ground that the pump is grounded to. So grounding is needed between the container being filled and the nozzle filling it. If the pump nozzle is in contact with a metal fill spout on the tank, static cannot build up. Or am I missing something?
   / Plastic Gas containers and Plastic liners in Pickups? #37
So that's why Amish use tractors with steel wheels. Not good with lightning during a thunderstorm, though.
   / Plastic Gas containers and Plastic liners in Pickups? #38
Gas stations could make life easier for the user if they had a 3' stand or shelf by fuel pumps for setting 5-6 gal. cans on. Great eye opening video by the way.
   / Plastic Gas containers and Plastic liners in Pickups? #39
Isn't the issue the fact that the jug tries to ground back thru the fuel hose because it's not grounded when sitting in the pickup bed? This being because the pickup isn't grounded when sitting on rubber tires?
If so your toy hauler isn't grounded thru the 7 port plug. It's simply "ground connected" to the ungrounded truck that's pulling it?
If so, adding a wire from your tank to the trailer hook up won't do any goog?
   / Plastic Gas containers and Plastic liners in Pickups? #40
Be nice if they had a swing hoist for us to use beside the non ethanol gasoline pump.
Ralph
2013 International (A53314)
2013 International...
23018 (A55758)
23018 (A55758)
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
