NH 6610S Emissions
   / NH 6610S Emissions #1
kbright
Member
Ford 3000
How do I quickly determine if tractor is emission controlled? Thanks
   / NH 6610S Emissions #2
If the fuel filter is retained with a large gray or black plastic ring the engine is emissionized. If the fuel filter is a conventional spin on element it is not.
Thanks!!! Thanks
   / NH 6610S Emissions #6
You appear to have four lines going from the injection pump - one for each injector. The tractor was manufactured from 1994 to 2003. I think it unlikely there is any emission control. A further indicator would be the throttle. If you have a mechanical throttle as opposed to computer controlled it is even less likely to have any emission control.
   / NH 6610S Emissions #7
You are misinformed. You can go to the New Holland online parts lookup and see the various parts diagrams for emissionized and non emissionized 6610S engine components. All Tier I and II as well as the vast majority of Tier III compliant off-road diesel engines use conventional mechanical injection pumps.
Thanks for input - the more I look at the parts diagrams and other info the more confused I become. Bought the tractor about 3 weeks ago. Have a shop manual but they have very limited info (same situation with other Fords I‘be had). Was buying filter and other parts to include operators manual - not sure what to order on several items.
Thanks for input - the more I look at the parts diagrams and other info the more confused I become. Bought the tractor about 3 weeks ago. Have a shop manual but they have very limited info (same situation with other Fords I礎e had). Was buying filter and other parts to include operators manual - not sure what to order on several items.
It has mechanical throttle.
Bush Hog 287 3 pt Mower (A50514)
Bush Hog 287 3 pt...
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51243)
KNOW BEFORE YOU...
