Randy
   / Randy
its a mahindra 4550 4wd not4540
   / Randy
   / Randy #13
No worries. It is an interesting project and I look forward to see how it works. Just be mindful of the forces involved to protect the loader.
   / Randy
I'll try to get one. The backhoe works as long as someone is on tractor pushing third function
   / Randy #17
That would be correct. I would not do that long though as the coil on the third function’s life will be shortened.
   / Randy
could you tell me what ports from diagram to hook up to hoe,sorry to bother you,I no nothing,dealers arround hear says it want work.
   / Randy #19
I sure will. I still would like to verify the backhoe valve as to not mislead you. The dealer is probably concerned about the loader being able to support the stress like we are. However, depending on what your plans are with the backhoe and take it easy you probably would not have issues.
Once you can post pictures of backhoe valve and a diagram I will draw the lines for you.
   / Randy
thank you very much ,iwill go take some pic, an get back in touch,Thanks
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2020 JOHN DEERE 8R 250 LOT NUMBER 185 (A53084)
2020 JOHN DEERE 8R...
