Yanmar Yss-60 spacer help
   / Yanmar Yss-60 spacer help #1
geckocycles
parker, co
Kubota BX22
I am looking for info on a yanmar yss-60 snow blower. I made a new drive flange and am having trouble getting some spacers off. There are 3 that appear to be the same. One on either end of the shaft by the outer bearings and one between the pto shaft and bearing, which is the one I need to remove. It has a set screw and also a indent for a spanner as if it was threaded. I need to know if this bushing is threaded or press fit before I put my puller on it. I tried to turn it by using a punch but no movement. RH thread?
I have been searching for hours to no avail
   / Yanmar Yss-60 spacer help #5
He says he is looking for the manual is my understanding. I emailed Martin diesel, no word back.
I called Schulte's. Seems they are either out to lunch, snowed in or on holiday break out there.
It would be super to get a manual from them. They do post manuals up on their website under support. There are a dozen there. Just maybe one matches the YSS60. hmmm
They should have parts too.
THanks for the info. I have word out to them as well.
After looking at it closer I determined that the bushing is NOT threaded. Looking into the set screw hole...no threads. Not sure why there is a detent in the bushing. Anyway I put on a puller and off came the bearing and bushing. I made it sound easy didn't I? LOL
Both the drive flange and the PTO shaft connection are only using 5/16" bolts to hold them on the input shaft. THe 1/4" key is not on either so the bolt is used as the drive.
I am debating whether or not to cut the keyway in the drive flange I made. I have the flange in the shaper now but don't have a tool to cut the keyway. It was a lot of work to get the drive flange off, so I think it best to cut the keyway and get some keys for the drives and not rely on the 5/16" bolts to drive the blower. Looking for the correct tool online now. I may have to make a boring bar type holder myself but I don't have the ideal material without cutting up a boring bar that I need for the lathe.
Mostly the 1/4" bolt connecting the drive flanges together has been my "fuse" and I have broke a few of those. The 1/4" bolts on the auger were really bent and hard to get out. Put new ones in. Grade 3. Grade 5 on the impeller.
   / Yanmar Yss-60 spacer help #7
Ah, glad to know it was a YS-60 instead. This should help anyone in the future looking for info. :)
CFG Industrial MH12RX (A50121)
CFG Industrial...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
Payment Instructions (A47384)
Payment...
2121 (A51244)
2121 (A51244)
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
