Buying Advice Snow, food plots and trails.
   / Snow, food plots and trails. #1
Bravo036
Kubota
Hey guys- looking at a new CUT to handle snow blowing at the cabin, 75 yards long with a push to left and right (200-300 yearly). Then head over to the deer land and keep up on brush mowing a total of 30 acres total once a year, meaning we just want to keep the woods pushed back in spots. Mow/Disc and overseed for deer plots (Maybe 20 acres on 240 acres) , some firewood and I知 sure loader work. So started on a B2650 cab but I think it痴 not enough tractor, I looked a JD 3033r, Kubota L3560 and a KIOTI CK3510SE all with factory cabs . The KIOTI came in at the same cost as the B2650 but lined up capability wise with the 3033R and L3560 which were 10k and 8k more.... or am I missing something? I don稚 want to underbuy but this is hobby at a place 3 hours from home so it痴 tough to justify to the better half how to fund this.....
   / Snow, food plots and trails. #2
Be ready for "Have you checked out ..."
I'll start it off. If you have a dealer close by, check out LS. Either the XR31 or the XR41 (my suggestion) series. Drastically increased capacity (loader lift and overall weight) with a slightly larger frame.
When I priced things out about 4 months ago, the LS was $7-8k cheaper than a comparably spec'ed Kubota or Deere, and it had higher weight and greater loader lifting capacity (important for me, sounds like it may not matter for you). However, Kubota was running a VERY good deal on the Kubota L3560SE, which is the 3560 with a few niceties removed.
   / Snow, food plots and trails. #3
Go big or go home.
I did look at the LS XR35 and it was real close in cost to the kioti and I thought very similar in capabilities or no? I honestly just didn稚 like the cab layout as much on the LS....
   / Snow, food plots and trails. #5
What tractor do you have now?
   / Snow, food plots and trails. #6
It's a very personal thing. Sit on a bunch and find what works for you. From the first time I sat on the LS, it felt best to me, but I'm not you.
The Kioti and LS were similarly priced when I looked too. For me, it came down to dealer, and that I could fit the XR4145HC in my garage, whereas the DK series Kioti was a couple inches too high.
Just a pair of old gassers at the farm, I couldn稚 even tell you what they are... the snow removal is new and just wanting to expand what we do at the farm.
   / Snow, food plots and trails. #8
I am happy with my Kioti but any of the brands mentioned would be fine. It is more about what you are comfortable in and dealer support.
   / Snow, food plots and trails. #9
The L3560 is way more tractor than a B2650 and sounds about what you need for that snow fall;may even want to look at a L4060.
The Grand L's with the HST+ are awesome ;lots of standard features that you will appreciate down the road.
I agree it逞エ an awesome rig but I遏・ trying to figure out how it逞エ $8k more that the LS XR35 or kioti ck3510? I guess I知 looking at the basics, HP for Brush hog/rear blower, loader capacity, even ground engagement stuff like a disc or single bottom plow. As a first timer what am I missing?
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
