Strange Drain Pipe Arrangement in my Pond
   / Strange Drain Pipe Arrangement in my Pond #1
ElmosBoy
Southeast Georgia
Mahindra 2555 Shuttle
New member,
Been lurking around for a few weeks, since buying my 2555 Mahindra!!!!). I have had some issues with my .8 acre, 7'-14', pond recently and just wanted to ask a few questions to see if anyone can offer some insight. :confused3:
I have an 8" vertical drain pipe that I assumed connected, via elbow to a horizontal 8" pipe that travels under my levy, out to a spill area for drainage. All of that assumption was correct except for the elbow...It ties into the horizontal pipe via a T...AND a ten foot section of horizontal pipe heads back toward the middle of the pond, as well as the 74-80 foot section that goes out to the spill-area. Now for the rest of the story.:confused2:
Had a clog, pond got REALLY high, my wife passed away on 12/17, so I was tied up with other matters & didn't notice until water was covering the deck of my dock. Friend of mine & I begin the process of "Unclogging" the drain pipe. We start from the spill-way end & pvc-pipe/pressure wash back up the length of the horizontal pipe under the levy. We encounter several blockages, (Feel like Blockages) as we push the cleaning device into the drain-pipe. We think we have it working, but the flow of water seems far inadequate for size of pipe.
We take another run at the pipe, just with the pvc push rod & VIOLA!!:cool2: Water comes forth in a big way and the vertical pipe is soon creating a whirlpool!!! :dance1:Life is good, we move on with our lives...
Until 3 days later, my daughter asks why the pond looks so ugly:confused2:....Because it has no water, or almost none...We discover that there is this section of pipe at the T, where the vertical drain pipe is that heads back into the pond...The only thing I can assume is that we managed to knock an end cap off of the pipe, during our cleaning effort, & allowed the entire pond to drain, except for 3-4 feet of water...
I have provided the owls, local coyotes, foxes, & whatever else shows up a smorgasbord of catfish & brim in the wet-lands my pond spills into...But even more importantly, I have to pray for rain & a quick refill of my pond, as it is the broader heat-exchanger in my "Surface Water Geothermal Heat Pump System", & problems heating & cooling my home are inbound if I don't get back some of the temperature exchange media, (Water), I inadvertently drained into the swamp...
All that to ask, why in the world did the Previous Owner run that 10' section of pipe back into the pond, t'ed at the vertical drain pipe??? Was it there to provide for complete drainage by introducing a long & strong enough push, thru the horizontal drain section, (Which I would have thought near impossible to force off against the pressure of that millions of gallons of water pushing back against it)...Or what?? Ideas or questions, I believe I have the pipe recapped, with a make shift cap, (You'd be surprised how few companies sell 8" pvc fittings on a Saturday in Southeast Georgia)...And have regained 10"-12" of water in 24- hours. Again any thoughts would be appreciated, sorry for the novel, but thanks in advance for ideas.:)
   / Strange Drain Pipe Arrangement in my Pond #2
First of all, sorry for your loss. Secondly, welcome to TBN. Curious what was used to clear the blockage on round 2 compared to round 1. I wonder too where the assumed PVC cap went as it should still be in the pond. I would guess two stand pipes since a .8 acre running thru one small stand pipe sounds inadequate. Most ponds in our area have large concrete storm sewer sized overflow stand pipes.
   / Strange Drain Pipe Arrangement in my Pond #3
The pressure on the PVC cap is not the pressure of "millions of gallons"
The pressure equates to the small column of water above the cap, so, minimal pressure will remove the cap,,
My neighbor has a sheet of window glass over the end of the "T" on his pond.
The idea was that he could open the "T" with the bullet from a 22 rifle,,, simply shatter the glass.
This was installed before PVC pipe was in common use, his pipe is steel.
   / Strange Drain Pipe Arrangement in my Pond #4
Just sounds like poor thought process with that design. I think I would have removed that section of pipe and just used a 90 ell while the pond was drained down.
   / Strange Drain Pipe Arrangement in my Pond #5
Yes - while the water is low I'd muck out there and get rid of the ten foot section of pipe that goes back towards the center of the pond. End up with just the vertical pipe - an elbow - the section that goes out to the levy. Since there is no understandable reason for this odd ten foot chunk of pipe and it's at the bottom of the pond - I would eliminate it.
I assume you are not able to contact the previous owner and ask - why???
   / Strange Drain Pipe Arrangement in my Pond #6
I'm thinking that the pipe setup was designed that way. What you did was use it as designed which was to drain the pond.
   / Strange Drain Pipe Arrangement in my Pond #7
Where I grew up, grandfather put in a 2 acre pond. Overflow always getting clogged, so he had a 3ft concrete culvert pipe on one end of dam up about 2ft above drainpipe. Other end of dam is a spillway, goes down around hill.
I fixed the clogging 3 years ago. I took a 55 gallon Rubbermaid trash can, upside down bolted a cement block to bottom, stainless bolts through to 2 angle iron pieces width of can across. This I placed over drainpipe with a helper from boat. I had to drill a 1/2" hole in bottom to do it (let air out).
Water has to enter down about 3ft, up can then down pipe.
Never had a problem since.
   / Strange Drain Pipe Arrangement in my Pond #8
That's my thought also, pmsmechanic. But there must have been some method to get to the cap and undo it - and then put it back on.
   / Strange Drain Pipe Arrangement in my Pond #9
You may be looking for the wrong thing ( a pvc cap) it may be merely a plate or shallow plug that fit the end of the tee. A cap would be hard to dislodge after a few years.
   / Strange Drain Pipe Arrangement in my Pond #10
What about a flat plate against the end of the pipe with a stout rope to shore. It will take a good pull to start it moving off the end of the pipe.
I kind of don't mind the idea of a piece of glass that gets shot out. Except for the broken glass....
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
