4720 oil pan bolt size
   / 4720 oil pan bolt size #1
randy41
Linden VA
so the property owners association tractor is a 4720. the oil has probably not been changed in years. I went and got a filter and oil but I don稚 seem to have the right size wrench or socket to remove the bolt. 24mm?
   / 4720 oil pan bolt size #2
An adjustable open end wrench ("crescent") use carefully should do it.. just be on size and square with the hex head.
thanks. My neighbor used an adjustable wrench to loosen it. When I tried it the wrench kept on slipping off.
   / 4720 oil pan bolt size #5
The "slipping off" part of that I do not understand.. especially if it was already loose.
   / 4720 oil pan bolt size #6
I use a 1-1/16" on my 4720.
dsb
   / 4720 oil pan bolt size #7
If it's rounded off you can find a replacement at Advance Auto. I don't remember the thread size. Just take the old one with you.
I had to remove mine with vise grips. AA had one that fits.
I tried to use an adjustable wrench on it before my neighbor did. he is more persistent then me.
JD5210 I tried 22mm but it was too small. The neighbor who loosened it with the adjustable wrench measured it to be 27mm which is about the same as what dsb5610 said, 1 1/16”.
I will try to get a replacement but at autozone since I get bad vibes at advance. Thanks TractorGuy.
   / 4720 oil pan bolt size #9
As posted above, the plug is JD part # RE46687, which is M22 x 1.5 and there is an O-ring that goes on for a seal. The O-ring is part # 51M7045
Sounds like it was tightened too tight and now buggered up..... When replacing, snug is good, any tighter not so good. Good that you are getting the oil and filter changed. Hope it ends well...
too bad it’s been neglected for so long. thanks for your kind thoughts.
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
BROCE BROOM RCT350 SWEEPER (A51242)
BROCE BROOM RCT350...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
