Heating. Propane vs Electric vs Wood Pellet
   / Heating. Propane vs Electric vs Wood Pellet #171
When I was young, foolish and cutting back hedgerows and selling firewood this is how Maple worked.
Green, green, green, rotten.
I was gonna say that. Green it won't burn. Dried burns like paper with little heat. :)
   / Heating. Propane vs Electric vs Wood Pellet #172
Curiously, how does that outdoor furnace work out? I've heard they consume quite a lot of wood compared to a woodstove, and take quite a while to heat up. Of course, you don't have to worry about ashes, dust, etc. inside the house.
A bit too hot for my taste. Usually keep my house 65-68.
When you get to be my age, 70 is cold......lol
   / Heating. Propane vs Electric vs Wood Pellet #173
The maple we have out here is not too bad, but I have noticed it does get punk after a few years. The bark does not come off which is part of the problem. If split, it can dry out okay. Different maple than you have though.
   / Heating. Propane vs Electric vs Wood Pellet #174
Sugar maple is great firewood. Soft maple isn’t.
   / Heating. Propane vs Electric vs Wood Pellet #175
We burn maple here. Our experience is not as bad as some of you report. Not sure if we just do not know any better (ignorance is bliss?), or our maple (northern MI) is better. The 12 cords of maple will be burned in the first 1-2 years. The other 20 cords delivered this past fall are mostly oak and will not be seasoned enough for next year anyway...the maple seemed like a good fit for my needs at the price.
   / Heating. Propane vs Electric vs Wood Pellet #176
Agreed about soft maple being poor firewood but I have acres of the stuff so it makes up a good percentage of my supply.
I try and use it during the shoulder seasons and save the oak, beech and hard maple for winter but the soft maple does burn and gets used along with the better stuff.
   / Heating. Propane vs Electric vs Wood Pellet #177
SR
   / Heating. Propane vs Electric vs Wood Pellet #178
Thanks for the chart Rob. Good stuff.
I have access to Hickory, White Oak, Red Oak and White Ash.
   / Heating. Propane vs Electric vs Wood Pellet #179
Interesting.
Doing a quick sample (Qty:4), it seems a lot of these wood types deliver 6400 BTU/lb.
This agrees with what I've always heard: That wood, no matter the type, has the same BTU's.......per pound (or ton, etc...).
It's just that it takes more pieces of some wood to equal that ton.
(...and drying to an equal moisture content will be different too, etc... )
...so you still have to lift, split and carry the same ton of wood to get the same BTU's. But with "lesser" "junk" wood, it's just more pieces, more splitting, more cords, more volume, etc....
but technically: it's the same "work".
....anyone believe this? ...and shouldn't wood be sold by the ton instead of by volume? (...but who has scales? ...and you'd need a moisture meter to factor/de-rate the load to some accepted standard...yeah...that might get complicated...but would be "truer" measure of BTU's purchased)
That being said: I like to burn the hardwood hickory, oaks, maples, beech, etc...
   / Heating. Propane vs Electric vs Wood Pellet #180
With lesser wood there's more work (physical labor).
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2018 BMW 430I  4DOOR CAR (A54607)
2018 BMW 430I...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
