Tractor Sizing Compact TLB for cutting trails into a sloped hillside?
   / Compact TLB for cutting trails into a sloped hillside? #1
agiardin
L2501 loader/backhoe
I'm looking to buy a tractor for a number of things around the house. Long term it will be used for general utility stuff, which almost any tractor could do. But I do have some trails that I want to cut around my property to make it more accessible. It's a steeply sloped property, steep enough that you probably couldn't drive straight up. I'm wondering if a compact TLB would be an acceptable tool for cutting some trails (just big enough for the tractor) into the side of a hill.
I have the following concerns:
- Are the compact TLB backhoes powerful enough to dig through rocky soil?
- How much wider do I have to make the trail than the tractor? If it has to be significantly wider than the tractor, I'm going to need to move an unbelievable amount of dirt.
- How much slower would a compact TLB be than a mini excavator? I realize that the mini excavator is probably the right tool for the job, but buying a tractor and an excavator is beyond my budget. And this project is going to be done a little bit at a time, so renting probably isn't a great idea.
I've been considering the following models:
- Kubota B2601 w/ BH70 backhoe
- Kubota B2650/L2501/L3301 w/ BH77 backhoe.
These tractors have front buckets of between 54"-66". The width of the rear tires on the L3301 is 60", and the B2601 is a little narrower at 50". The stabilizers on the BH77 are 69" wide, and the BH70 is narrower at 73". Would the narrower tractor, with the less powerful and slightly shorter backhoe, actually be the better tool for the job since I could make the trails a little narrower? Or would it be better to go slightly wider and get a more capable tractor in general? Or is using a little TLB for this job a fool's errand in the first place?
   / Compact TLB for cutting trails into a sloped hillside? #2
Any machine where you have to climb off the operator seat and onto a backhoe seat is not very productive and you will start to hate it real quick. If you are moving a lot of earth a larger mini-ex with front blade or a small trim dozer will be more suitable than a CUT or SCUT with a backhoe attachment. Id suggest you try renting a compact TLB machine and trying it out on your site before making a decision.
If you have to make cuts, yank trees, move a lot of earth and move rocks then any machine under 5 tons is going to be a slow painful struggle. Get a thumb with the mini-ex. SCUTs with backhoes are great for digging small trenches in back yards with tight access but not well suited for making cuts, roads, and moving lots of soil.
   / Compact TLB for cutting trails into a sloped hillside? #3
Or is using a little TLB for this job a fool's errand?
Tractors are unstable working on slopes. With conditions you describe high probability of a rollover.
An excavator is the right machine. Excavator has a rear engine. Tracks are much more stable than tires. Excavator swivels 360 degrees.
Second choice would be a (rear engine) tracked skid steer usually termed a compact track loader. (CTL)
Have you considered the possibility of erosion undoing your work?
Few here would agree with you that "almost any tractor could do."
How large is your property? How many acres do you plan to tractor over, long term?
It's not a large property, about 10 acres. About 1.5 of that is flat already. I've marked out about 1500' of trail that I would like to ideally have, to get to the top of a hill behind the house, and also to maintain fire breaks around the perimeter.
I don't think a CTL would be able to do the job. A lot of the soil is very rocky. I've tried digging into the hillside with the FEL on an L-series (maybe 4000 pounds?) And it didn't work very well. I was very slowly chipping away and I don't think the FEL would have survived long being used like that.
I'm not too concerned about erosion. I don't get a lot of rain where I am, and the soil is so rocky that it's pretty stable on it's own. 2 years ago I cut some walking trails by hand into the hillside for a couple hundred feet, and they are still in great condition.
As far as rollover is concerned... If I start on a flat spot, and proceed up the mountain cutting a level trail into the side, the machine will only ever be on a level surface, right?
   / Compact TLB for cutting trails into a sloped hillside? #6
Describe your land by segment.
How much land is around the house?
How much land is occupied by formidable slope?
How many acres, less yard, less slope, do you plan to tractor over long term? What you do you foresee for this segment? Is it flat or sloped?
   / Compact TLB for cutting trails into a sloped hillside? #7
agiardin
A rear engine CTL is designed to lift and dig. Hydraulic pumps have much higher flow than tractors. Huge numbers of construction attachments are available. A 5,000 pound rear engine CTL is multiple times stronger for construction work, relative to a 5,000 pound front engine tractor.
Tractors are designed to pull.
An excavator or small bulldozer would be equipment of choice. CTL third choice.
Just tell us what state you are in.
Wrong. I do not want to flame you. All writing here were new to tractors in the beginning.
The heavy work you describe should only be done from the tractor's (rear) Three Point Hitch. Tractor are designed to PULL.
Loaders are an option for those wishing to move relatively light, loose materials. Optional Backhoes are not that strong on COMPACT tractors due to low flow hydraulic pumps appropriate to machines designed to PULL and the stability problem is still out there.
   / Compact TLB for cutting trails into a sloped hillside? #8
Not a job for a tractor mounted backhoe.
Mine will dig rocky soil as long as it isn't overly dry. Any amount of recent rains make it possible.
You would never want to dig without the outriggers fully deployed. In my case, that makes the width about double that of the tractor itself.
FELs are made for loading loose material, not digging.
Best laid plans and that guy Murphy say that level isn't what you might think it is.
Here's a picture of what I'm dealing with. This is just about the steepest slope that I have. The tape measure on the ground is 66" long, for scale. As you can see, I really need to make this more accessible to clear this junk out.
This is in northern California, in the foothills.
   / Compact TLB for cutting trails into a sloped hillside? #10
Mine is probably one of the narrowest machines available and I need a width of 72" at least to be anything close to maneuverable.
Could I inch my up that trail, moving material from the right to the left? Maybe.
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
