Good 5 gallon pail fluid pump?
   / Good 5 gallon pail fluid pump? #1
Dataway
Gold Member
Greenfield TN
Ford 1715, BX2200
Anyone have recommendations for a decent pump that fits the typical 5 gallon hydraulic oil buckets? I'm tired of spilling it trying to pour into strange funnels that reach the fill points on my tractors.
Thanks
   / Good 5 gallon pail fluid pump? #2
The Northern Tool oil extractor pump should do it. I used it to pump diesel from my 5 gallon container to avoid having to lift it up onto the hood. It worked one time to extract hot oil from the Mz3 but would not work on the Mx5 because the hot oil caused a tiny leak in the seals. Seals were fine for pumping the cold diesel out of the container.
Ralph
Jeez, they have a lot of stuff there. I see a couple of things that might work for me. I'm actually looking for a hand pump that fits into a 5 gallon hyd oil container to pump it into tractors. So more of a transfer pump I guess.
   / Good 5 gallon pail fluid pump? #5
   / Good 5 gallon pail fluid pump? #6
+1 on the northern pump - have one and use it lots. Good to pump oil into tractors, etc. - it has a hose and a J hook on the end.
I also use XP Optilube and bought their 5 gal pail kit with a pump Pump works very well for that stuff (kinda slimy and a little thin, and oh ya, stinky). 2 minutes of searching turns up the pump alone on amazon
Optilube kit
https://www.amazon.com/gp/product/B01KGLY59O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Pump Only
https://www.amazon.com/AES-Industri...1-3-dd5817a1-1ba7-46c2-8996-f96e7b0f409c&th=1
   / Good 5 gallon pail fluid pump? #7
The Northern pump has served me well for many years. I used it pump hydraulic fluid, bar oil, gear lube.
   / Good 5 gallon pail fluid pump? #9
I've used this 12v pump for diesel and changing the 10 gal of hydraulic fluid for years. It's so cheap, I actually bought 2 thinking it might burn up after pumping the hydraulic oil, but no issues at all.
It has a 3/4" outlet, so it fills my 9 gallon diesel tank in about a minute.
Still have the 2nd one, new in the box, in a cabinet in the garage.
12V Submersible Diesel Fuel Water Oil Transfer Drum Pump 8GPM Mini Refueling Sub | eBay
Might give the Tractor supply item a shot .... that way I can leave the pail top sealed ... plus, space is at a premium and it wouldn't take up much room.
Excellent suggestions, thanks folks.
2006 CATERPILLAR 252B SKID STEER (A51246)
2006 CATERPILLAR...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
