Buying Advice 72" Finish Mower replacement blades...where do I get 'em?
   / 72" Finish Mower replacement blades...where do I get 'em? #1
Spudgunner
Gold Member
Central Idaho Mtns
Kubota BX-23 & Toolcat 5600 D
The title pretty much asks the question, but the backstory is that I found a used 72" Bobcat Finish Mower for sale that I ended-up buying. During the inspection of the mower, I did find that the blades badly needed sharpening. I think there's plenty of meat left to grind on when I take the blades to the local sharpening guy, but if not I was wondering if there was brand/type of blade (e.g. Oregon?) that might be recommended. I can get the Bobcat part, but Bobcat (other than maybe hydraulic fluid) seems to put a pretty heavy price tag on their stuff and I have yet to find a place to order Bobcat parts online. (My nearest Bobcat dealer is about 70 miles away.)
Thanks in advance for any and all help!
   / 72" Finish Mower replacement blades...where do I get 'em? #2
Measure the length and center hole and get on a mowing website and order some for probably $15 a blade. Do you have a picture of yours?
   / 72" Finish Mower replacement blades...where do I get 'em? #3
Local, Amazon, eBay, etc.. no magic in most blades.. length, center hole, thickness, style (high lift, etc).. I bought mine off Amazon just for convenience.
No pic as I haven't taken delivery yet. That's tomorrow's job.
   / 72" Finish Mower replacement blades...where do I get 'em? #5
I had to do quite a bit more to find blades. I could find 'almost' but not exact. Combination of length, width, thickness and center hole was a bit uncommon and none of the major brands crossed. More or less accidentally stumbled onto a clone offered by Northern Tool. A little more digging showed that it was made by the same company and from there I could get a match at their parts service. Paid something less than $75 for a set of three. Since BC likely didn't make their own mowers, it was probably made by one of a handful of OEM suppliers.
   / 72" Finish Mower replacement blades...where do I get 'em? #6
Bottom of mower:
   / 72" Finish Mower replacement blades...where do I get 'em? #7
The book says the blade is 5/16 x 2.5 x 25" and you should replace when blade is sharpened past 2.25" (1/4" gone).
Thanks to all who responded. Here's a bit of a wrap-up... I removed the three blades and, as it turned out, when I checked-out the blades at the seller's place I accidentally picked the worst of the three to examine for wear/damage. There's plenty of meat left on all the blades, so no new blades are required. I did do a bit of research, though, in case new blades were going to happen. Other than the Bobcat blades, I didn't find anything that would simply bolt-on. The middle hole of the three holes on each blade is 1.2" in diameter and I didn't find anything with a center hole that big. Nor did a find a blade that had a 5.5" center-to-center dimension for the outboard holes. (BTW, the center hole is simply to access a bolt head..the two outboard holes actually fasten the blade to the rotating gizmo.) FWIW, the two outboard holes are .5" in diameter.
We still have between 12"-18" of snow...so the sharpening dude won't need to be in a rush.
2008 Ford F-250 Service Truck with Liftgate (A51692)
2008 Ford F-250...
Cat TH407C Telehandler (A53472)
Cat TH407C...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
1264 (A50490)
1264 (A50490)
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
