OEM Mahindra hydraulic Filter? How do I know that this filter is genuine?
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #1
1acre
Mahindra 2615
I just bought some filters for my 2615. They were advertised as Genuine Mahindra filters. Are they supposed to say "Mahindra" on them? None of mine do. The hydraulic filter is just plain black with the part number on it. Is that what the real filter looks like?
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #2
Did you get them from a dealer or off some random web site , vendor
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #3
If it's under warranty. I would recommend the OEM filters.
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #4
I have a Mahindra 1526. Which I think is about the same. Mines just newer. My filters are solid black also. The hydraulic filter part number is 19642509000. The part number for the HST transmission Is 19682581000. The boxes are solid white with a white and red them. That say Mitsubishi genuine parts on them. 1580497231632.jpeg
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #5
Just checked both hydraulic filters on my 2615. Both are black with part numbers only. These filters are used on other brands of tractors, too. If you have the correct part numbers, don't worry. To be sure, compare gaskets.
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #6
Plus one for the OEM filters, specially the hydraulic ones.
It's very common for various brands to burn hydraulic pumps or have poor performance on the hydraulic because the owners bought aftermarket filters that looked the same on the outside but internally are setup differently than the OEM, causing the pumps to starve for oil.
I have a Mahindra 1526. Which I think is about the same. Mines just newer. My filters are solid black also. The hydraulic filter part number is 19642509000. The part number for the HST transmission Is 19682581000. The boxes are solid white with a white and red them. That say Mitsubishi genuine parts on them.View attachment 639487
Same filter as mine. Thanks for the pic. I guess I have nothing to worry about:thumbsup:
   / OEM Mahindra hydraulic Filter? How do I know that this filter is genuine? #8
Those are the OEM filters in the photo.
My dealer recommended the OEM HST filter since it sees higher pressures. Some of the aftermarket filters fit but may not be designed for the high pressures. The other filters have cross references to the common brands- Wix, Donaldson etc. Their are a few threads in here that should list them.
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2008 Ford F-550 11ft Flatbed Truck (A52377)
2008 Ford F-550...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
