3-Point Hitch Aftermarket source for mechanical top link repair end (category 1 metric)?
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #1
finitor
LS XG3140H
Hey there, XG3140H owner here. I bent the upper adjustment bolt of my mechanical top link, the left-hand threaded one with the ball at the top. Dealer wants over $100 for the OEM replacement, so I am trying to do the fix with an aftermarket part. I know I can buy a whole new top link from Tractor Supply for like $30, but would prefer to fix the existing one so I don't waste so much metal. Thing is all the aftermarket ones I'm seeing are imperial, and the OEM one (according to the parts sheet) is metric, M24x3. According to my research 1" imperial is a close match for M24 though I don't know about the thread pitches. I found one 1" LH cat 1 top link repair end online, can anyone speculate about whether it would work, or point me to a source for one that does? Thanks! - Tim (Wawa, Ontario)
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #2
yeah the thread pitch will be the biggest issue, metric is definitely different. I recently had to replace a hydraulic hose on my harbor freight log splitter and was next to impossible to match. I had to have a shop cut the end off my hose, and machine it to the end of a new hose. pain the rear and cost 3 times what a generic replacement hose should have cost.
good luck finding what you need! You may just wind up going new all the way and add that metal to your scrap metal pile, although I could think of a few things I'd try to make out of it :)
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #3
Can you remove it?
If so, remove it and straighten it.
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #4
WOW, if it bent, then it was defective!. replace it!..
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #5
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #6
Why is it defective? The OP clearly said that he bent it. Probably by hitting the ROPS when folded or something alike.
Sometimes I wonder if you read the posts at all.
Back to the topic, I'm not sure if you are able to find a metric end for that. You might have to get a new unit instead.
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #7
I'm thinking we need more information.
I'd probably have it straightened and rethreaded if possible. Though that might cost more than the replacement.
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #9
fine, then YOU help him!..
   / Aftermarket source for mechanical top link repair end (category 1 metric)? #10
You are going to incur way more than 30 dollars worth of headache trying to reuse that piece -
go to TS and be done with it
2011 IHI IC75 Weld Deck Crawler Carrier (A47371)
2011 IHI IC75 Weld...
(1) 12ft Tarter Livestock Panel (A48837)
(1) 12ft Tarter...
2013 Mack CHU613 Truck, VIN # 1M1AN07YXDM014973 (A48836)
2013 Mack CHU613...
2019 FREIGHTLINER CASCADIA DAY CAB (A45679)
2019 FREIGHTLINER...
2019 CATERPILLAR 289D SKID STEER (A50458)
2019 CATERPILLAR...
County Line 3pt Hitch Single Plow (A48837)
County Line 3pt...
