New Holland TC45 Trans/Hydraulic oil
   / New Holland TC45 Trans/Hydraulic oil #1
trucker12
Conway NH
TC45
Hi I have a new holland tc 45 and the manual calls for Ambra Multi G 134 hydraulic /trans oil. Does anyone know the tractor supply oil that is equivalent. I have looked at all of the hydraulic oil they carry in stock and none have that mentioned in there specs. The manual also says to use that for the power steering. Thanks
   / New Holland TC45 Trans/Hydraulic oil #2
Is your tractor a hydro or shuttle?. You should be okay with tsc premium hydraulic fluid. if you want to spend more money then look at the synthetics like chevron or kubota oils.
   / New Holland TC45 Trans/Hydraulic oil #3
I'm almost positive Tractor Supply's Traveller Premium Universal Tractor Trans/Hydraulic Fluid (SKU: 80639199) meets the 134D spec.
Traveller Premium Universal Tractor Trans/Hydraulic Fluid, 5 gal. at Tractor Supply Co.
I do Not use it in our TC40... so double check the label but again pretty sure you are cover spec wise...
Thanks 3gunr for your reply. I'm not sure on the hydro or shuttle I just bought this tractor and drive it sorry for my ignorance. But if hydro is like my lawnmower no I have a clutch so I guess it must be shuttle shift.
   / New Holland TC45 Trans/Hydraulic oil #7
Viscosity Oil has been the North American blender, packager and distributor for CNH branded oils since CNH has existed. Viscosity was recently acquired by Petronas.
   / New Holland TC45 Trans/Hydraulic oil #9
It still needs TSC Premium (JD J20C spec is what I use for a gauge since if any spec is on a container and the product is rated for such, J20C will be the one listed) since you have hydrostatic steering and wet brakes to consider also. I run it in my Bransons and the Ford 3910 since it has wet brakes. The other two Fords don't need it so they get regular Trans-Hyd fluid, used to be listed as JD 303 on most containers. My 6530 is clutch assisted shuttle.
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
40ft Shipping Container (A52377)
40ft Shipping...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
Utility Trailer (A52377)
Utility Trailer...
