3-Point Hitch Hydraulic side lift for a CK2510
   / Hydraulic side lift for a CK2510 #1
Buggs67
Perry Cty, Pennsylvania
Kioti 2014 CK2510 TLB
Has any one added a Hydraulic side lift to a CK2510 or similar Kioti? Before I speak to the dealer I'd like to well informed enough to decide if I should cobble together a kit myself or purchase a system from him.
I already have quick connects on the rear for my Back hoe and thought all I'd need is a valve and a cylinder to replace the adjustable side lift link.
Any advice is much appreciated. I do have a retired farmer and a retired machinist as neighbor/friends and they might be able to assist in installation and modifications.
   / Hydraulic side lift for a CK2510 #2
Think you're talking about a hydraulic tilt link, correct? I've seen a few put together on other forums. You may want to try posting in the "Build it Yourself", "Hydraulics", or "Customization" forums.
   / Hydraulic side lift for a CK2510 #3
If you are talking hydraulic Tilt for the 3 point hitch I have not found one that you can piece together. But Fit Rite Hydraulic's
does make the (Custom) for the CK2610 and all Kioti's Fit rite Hydraulics.JPG
   / Hydraulic side lift for a CK2510 #4
We manufacture Top-N-Tilt Kits for all KIOTI Tractor Models, and some "others" also. Our Hydraulic Top Links always include a Lock Valve, Side Links for the NX Series and up can be supplied with Lock Valves as an option. All of our Top and Side Link cylinders include the hoses, fittings, and couplings for plugging into KIOTI Rear Hydraulic ports.
Hope this helps.
   / Hydraulic side lift for a CK2510 #5
Buggs67, further to MIE's post, I have their top 'n tilt toplink and sidelink kit on my CK3510SE, as does one of my neighbors on his CK3510SE. I can vouch for the quality, and the quick turnaround on orders. I think it's around 10 to 14 days.
I've also had an MIE hydaulic side link for nearly five years on my NX4510HST Cab, with a lock valve. Never a problem with it.
One additional data point for you: Another neighbor recently added the MIE top 'n tilt kit to his DK53010SE HC. He, too, is very pleased with the setup.
Another poster mentioned Fit-Rite for custom top 'n tilt components. Brian at Fit-Rite really knows his hydraulics, and all reports are that his kits, and his service, are first-rate.
   / Hydraulic side lift for a CK2510 #6
Hope this helps.
MIE, in addition to the NX series and up, I'll note that your lock valve will also fit on your side link for at least some of the Kioti DK10 series. As I mentioned to the OP, one of my neighbors recently added your top 'n tilt cylinders, both with lock valves, to his new DK5310SE HC. The kit fits perfectly.
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A48081)
2008 Ford F-250...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A50397)
John Deere 5090E...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A48081)
2005 Toyota Tundra...
1998 Ford F800 10 Cu. Yard Dump Truck (A48081)
1998 Ford F800 10...
