Gravel driveway maintenance - best SKIDSTEER option?
   / Gravel driveway maintenance - best SKIDSTEER option? #1
flashpuppy
Triad, North Carolina
Kubota M7040 Kubota SVL75-2
I believe it is fairly universally agreed that a LPGS is the ideal implement for gravel driveway maintenance behind a tractor. I am another pretty firmly believes this to be true. How about on the front of a skidsteer?
I have a 3/4 mile driveway and another 1/2 mile driveway. Seems the problem with most of the LPGS style attachments for a skid steer is that they require one to operate in reverse. I do not want to back all the way down, I would prefer to drive forward.
What about something like this?
I have also seen the 斗and sculptor type attachments. Anyone have any experience with them?
   / Gravel driveway maintenance - best SKIDSTEER option? #2
To finish, they still go in reverse with that attachment. ^^
   / Gravel driveway maintenance - best SKIDSTEER option? #3
Maybe a grader attachment?
   / Gravel driveway maintenance - best SKIDSTEER option? #4
Up for a road trip to MD?:
https://www.machinerytrader.com/lis...ent/for-sale/190839923/1970-allis-chalmers-dd
Listed at a mere $5K
   / Gravel driveway maintenance - best SKIDSTEER option? #6
So now you have a nice driveway and an old grader junking up your place. Can't win.
I find my 8 foot 3ph Harley leaves a washboard on the driveway although it grades nice. Need to pull a chain harrow over it afterwards, but that's another step.
   / Gravel driveway maintenance - best SKIDSTEER option? #7
What ever you get make sure you can put a crown in the driveway. No crown and water makes for a crappy driveway quick.
   / Gravel driveway maintenance - best SKIDSTEER option? #8
That is why I have not bought a land plane for the SSQA...............how would you make a crowned drive? At least with the 3pt I can adjust one side higher to push debris to the center.
As far as crowns go, my driveway is 12’ wide or so. I have a defined crown now. If you stay on one side or the other, the machine follows the crown already and matches it. I don’t run the land plane down the center as that would remove the crown.
For re-establishing a crown, you work 90 degrees to the direction you drive and get the count out where you want, then just like above, stay on that grade and you will re-cut that grade. I have a pretty hefty machine (SVL75 Kubota) and it does a good job that way. I have cut driveways with just a bucket and have become pretty proficient at crowning with a skid steer.
   / Gravel driveway maintenance - best SKIDSTEER option? #10
If the attachments sole job was smoothing driveways you could weld the SSQA plate on crooked. If you couldn’t order it that way or didn’t want it permanently crooked you could make an adapter to hold it tilted. Or the best and most expensive solution would be a hydraulic tilt plate. Quick Attach® Quick Tilt Tach? Skid Steer Tilt and Angle Attachment - YouTube
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
1261 (A50490)
1261 (A50490)
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
