Left Brake Locking up
   / Left Brake Locking up #1
Tim_in_IA
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
on my 6500 4wd my left brake has started locking up. If I pull the pedal back it seems to be ok for a while. The spring seems to still be ok on the pedal. Ideas on where to start troubleshooting? It is fairly dangerous when I am working and all of a sudden it steers off in another direction than what I am expecting.
Thank you
   / Left Brake Locking up #2
If you can pull the pedal manually and have the brake release your spring may have weakened over time. I'd start by replacing both with new springs.
   / Left Brake Locking up #3
Not having any idea what type of braking system you have, just guessing.
Assuming hydraulic brakes? Also assuming internal oil bath brakes? Not much can go wrong in there unless the tractor has a gazillion hours on it.
Maybe the pedal swivel is dry and binding? Do they have a grease zerk on them at the swivel point? Do the pedals return easily when you take your foot off? Does the right one return as it should and the left one not? That might indicate a swivel problem.
If they are not power brakes, the left side will have more linkage to deal with and more chance of binding.
I'd start by tracing the left brake from pedal to activator.
Richard, yes left side is the issue. I've traced it through and to the other side. No visible zirk on the pivot that I could see but I'll check again. Spring looked ok but may be weak. Just doesn't seem to want to return every time. Stop pad is missing on pedal but that shouldn't really matter might just make a noise when it returns. They are wet disk brakes.
   / Left Brake Locking up #5
So if you work the pedal by hand it freely moves?
   / Left Brake Locking up #6
Is there a reason you don't have the two brake pedals locked together?
As others have mentioned, springs and lubrication could be the issue but it still pays to lock the two pedals together unless you specifically need to use them separate.
   / Left Brake Locking up #7
Only time I lock my pedals together is when trailering. Allows me to lock both brakes with a one pedal locking mechanism.
Why would you want your brake pedals locked together?
   / Left Brake Locking up #9
To even out the wear on both brakes.
Wet brakes wear at such a slow rate that you'd never notice the difference. If that's important, when applying the brakes center your foot on both pedals. Then you have the freedom to select either wheel by moving your foot slightly one way or the other if the pedals are unlocked. And you can use them for steering brakes which was the original idea. :)
   / Left Brake Locking up #10
I always keep brakes locked together. Unless you need to steer with the brakes. Who wants to make a quick unexpected turn into the Rhubard?
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
Fire Place Mantel (A49462)
Fire Place Mantel...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2010 Case 660 Trencher (A50322)
2010 Case 660...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
