Did your existing FEL valve use 6 or 7 hoses?
7 means it has power beyond likely to feed the rear of the tractor.
My existing valve has only 6 ports. 2 ports coming from the distribution unit under the tractor. I assume 1 is the load and the other is the return. The other 4 ports on the valve go to the FEL. The new 3-spool has 8 ports, 2 for load&return, the other 4 for the FEL and the remaining 2 ports for the grapple. No PB port. I got it from Amazon sold by Summit for about 150 bucks. The max flow rate is 11 gpm where the rate on the tractor is 9.3 gpm. My Kubota was designed to have a backhoe, so I do have one unused remote above the PTO coming from connections on another heavy duty distribution unit under the seat. I'll use this remote to power Top- n-Tilt links. I've also purchased a new 2-spool valve to operate the links. I'll route the hoses from the remote to the valve where I'll install on top of the right rear fender, then more hoses from the valve to drive the T-n-T. The 2-spool unit is 120 bucks.
What do you guys think?
Old and tired: Here is the link to Amazon page:
Amazon.com: Monoblock Hydraulic Directional Control Valve, 3 Spool, 11 GPM, SAE Ports: Home Improvement
