Tires 2018 EMAX 22s tire pressures
   / 2018 EMAX 22s tire pressures #1
mcleod9
Mahindra emax 22s
My manual does not give suggested tire pressures. What seems to be the best for this tractor with a front end loader? Not liquid filled. (2018 Emax 22s)
   / 2018 EMAX 22s tire pressures #2
The tires should have a max written on the sides and running near the max is a good starting point. It will depend on the tire type (ag, construction or turf) and your intended use.
If I was guessing the backs would get 15-25 and the fronts would get 20-30. But those are SWAGs.
   / 2018 EMAX 22s tire pressures #3
What he said, sidewalls will have a max pressure which will also be for the max load. ie:loader and backhoe or ballast installed. Many tire manufacturers have pressure vs load charts for their tires so if you’re going to use only you mmm or pull a cart without the loader you might want to air down the tires for better traction and ride.my max loading is 20/25psi. When I take the loader/hoe off I air down to 12/18. I assumed a 60/40 rear/front weight split on the charts. Found out about the charts in a debate over what pressure to run light truck tires vs P series tires. Just cause the light truck says 65psi on the sidewall doesn’t mean that’s where it should be inflated. Just means if your carrying max load rating for the tire that’s the pressure.
Souds about what I thought. I'm doing 24 in the fronts and 20 in the rears. Thanks to all who replied.
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2007 Ingersoll...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
Fifth wheel multi use trailer. (A51039)
Fifth wheel multi...
