1715 Wiring Diagram
   / 1715 Wiring Diagram #1
Walt H
Member
Malibu, Ca
NH 1715
Anybody have a wing diagram of a 1715? My service manual seems to have disappeared.
Thanks, that helps. Looks like they are pretty close except for the dash. Are there any color codes for the wires in your manual?
   / 1715 Wiring Diagram #6
Can anyone tell me what fuses go where on a 1715 new Holland? There is no fuse for fuel gauge or headlights and the owners manual is useless, I found there is a 15 amp and a 5 amp but which one goes where?
Thanks
   / 1715 Wiring Diagram #8
Here is the 1715 diagram I have ... however ... if I recall correctly my 1715 has a 15 amp and two 5 amps. Looks like the slot with the yellow wire is the 15 amp for the headlights?
   / 1715 Wiring Diagram #9
Thanks
15 amp for the headlights, and 5 amp for the gauges. there's an easy way to tell which fuse does what. temporarily put the 15 amp in one of the holders, and see what works.. then put the correct fuse in when you find out what comes on..
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CHALLENGER MT 525B TRACTOR (A58216)
CHALLENGER MT 525B...
case 370 glass door never installed (A56435)
case 370 glass...
LOT: (4) Jack Stands (A59076)
LOT: (4) Jack...
PALLET OF SCRUBBER PODS (A58216)
PALLET OF SCRUBBER...
JOHN DEERE 750 (A58216)
JOHN DEERE 750...
