New holland 3010 fuel injection pump problem
   / New holland 3010 fuel injection pump problem #1
myboyblue85
623BD0F7-CFE5-4BA0-893E-24EA288633E8.jpegCD3C43A8-0BB9-4DEC-A264-61E4AB846899.jpeg73485616-9042-410A-9122-332EFE3C132B.jpeg7836E2B8-ED17-4229-8BC5-C42603BC1FFB.jpegHey guys, I am trying to remove the fuel injection pump on my new holland 3010, but having a hard time. Ive got all the bolts removed and hoses disconnected. Am I missing something? Anyone have any tips or advice? I cannot seem to find the shop manual anywhere and my local dealer has not been super helpful.
Also any particular timing marks I should be looking for? Thanks in advance.
   / New holland 3010 fuel injection pump problem #2
Good morning, did you ever figure it out? And what was the reason or what was tractor your tractor doing? I have a 97- 3010s and it just stop like someone turned off the key. I could get fuel to bleed screw but nothing to injector lines.
   / New holland 3010 fuel injection pump problem #3
Did you follow the bleeding instructions? If you have fuel to the bleed screw at the pump, the next step is to bleed the injectors. Make sure the battery is fully charged before you start.
   / New holland 3010 fuel injection pump problem #4
Yes I did everything you could think of. Thanks for the reply. I fixed my problem Saturday. I replaced the fuel solenoid and it fired right up. Turns out the original 1997 solenoid finally called it quits.
   / New holland 3010 fuel injection pump problem #5
The orig. question was how to remove..
I can see from your orig. pics. that u havent removed the front cover infront of the inj, pump..
Under that cover, you'll see a large nut & washer that connects the inj. pump to the drive gear..
You'll need a puller to pop the gear off..
FYI> the inj. pump to engine timing is critical.. so u need to read up before pulling the pump..
Glad u fixed the problem.
1990 GREAT DANE 28' REFER (A52472)
1990 GREAT DANE...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
