John Deere 6400 losing prime? Wont start after cold.
   / John Deere 6400 losing prime? Wont start after cold. #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
Ok it runs fine but if you shut her down and let her sit over night it won't start right away the next day.
We turn the key on and wait and it will fire off and die. Work the throttle and turn key on wait and then try again and it just turns over and won't start. Turn it off back on again and turn it over again and after maybe 30 seconds it will fire off and run fine. If you shut it down and try to start right away it starts no problem .
Am I losing prime or is there an electric fuel pump that might be messed up?
Any ideas?
thanks in advance.
   / John Deere 6400 losing prime? Wont start after cold. #2
Needs new rubber fuel lines. I'm surprised on a 6400 they haven't already been replaced. For some reason John Deere uses some kind of fiber lines on those tractors and as they age they get so they leak enough for air to get into the system if they set awhile (like overnight), then you have to run the starter enough to purge th air before it will start.
All the tractors I've had with those lines I've had to replace eventually. Pretty sure that's your problem.
   / John Deere 6400 losing prime? Wont start after cold. #3
there should be a small check vale in the fuel line - replace it or add one deere sells them
   / John Deere 6400 losing prime? Wont start after cold. #4
I had to replace the fuel lines on my 2006 JD 6415. multiple leaks. I used Gates Barricade hose. They make it in both high and low pressure. I used the low pressure. High pressure is for fuel injected gas engines.
Ok thats what we will do and see what happens. We just bought it in May so still going through it finding a few things seems to run pretty good otherwise.
I will update when done.
Thanks!!!!
   / John Deere 6400 losing prime? Wont start after cold. #6
The OD of Gates hose was bigger than what JD used, so I had to order new clamps, which delayed my hose change by a few days. Just heads up. I still used the "squeeze" type band clamps, not the worm gear style. I found them on Amazon IIRC.
   / John Deere 6400 losing prime? Wont start after cold. #7
"squeeze" type band clamps, = Oetiker :2cents:
Clamps & Rings
Unused Dingo Quick Attach Plate (A55272)
Unused Dingo Quick...
Scotchman 9075C1280 Hydraulic Press (A59213)
Scotchman...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
3 Wheeled Power Dump Cart (A55272)
3 Wheeled Power...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
UNUSED IRMC HIGH END MASSAGE CHAIR (A58376)
UNUSED IRMC HIGH...
