Homemade Leaf/Firewood Scoop
   / Homemade Leaf/Firewood Scoop #1
AStanton
North Central, CT
I had some scrap pieces of plywood hanging around. So this past fall, I constructed a leaf scoop to gather raked leaves. I also found the scoop gave me double or bettter bucket capacity to move firewood. The depth of the scoop is 42".
   / Homemade Leaf/Firewood Scoop #2
Good idea! I must have moved 300 FEL loads of leaves this past Nov, from the front yard to the back corner pile. Sure wish I'd seen this.
How do you keep the bottom from sliding out when you dump the bucket? Does that 1 chain hold it in? KW
   / Homemade Leaf/Firewood Scoop #4
Brilliant, that is now on my to do list.
Sent from my iPad using TractorByNet
   / Homemade Leaf/Firewood Scoop #5
Very cool! I built one on a carry all for firewood and it works great. I made it a detachable wooden platform and bet it could be adapted for the bucket too.
   / Homemade Leaf/Firewood Scoop #6
Can you share your plans for this, or maybe a few more pics? Thanks :thumbsup:
KW,
I attached a couple more pics for you of the scoop. There is no right or wrong way to do this thing. Just make sure you have about 1/2 inch of clearance on each end of the scoop between it and the bucket. I also used bolts to strengthen the 2X's attachment to the main piece.
Good luck.
   / Homemade Leaf/Firewood Scoop #8
Thanks! If I don't start this for firewood this season, surely will by fall leaf time.
   / Homemade Leaf/Firewood Scoop #9
Thanks everyone. Pretty clear there is not a turn key solution for lazy guys like me. But I do have scrap wood and quite a few saws and tool; I think I can make this work. We also deal with Ponderosa Pine needles, which I have seen others reference. They are a pain to pick up and move; this will work well for that too.
If anyone has more innovative ideas for this application keep them coming. Great stuff; thanks again.
keith
   / Homemade Leaf/Firewood Scoop #10
keith
You do realize you posted to an 7 year old post. Did you post to correct post? :eek:
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
CATERPILLAR D6R XL HI-TRACK CRAWLER DOZER (A52707)
CATERPILLAR D6R XL...
Ford Metal Tailgate Art (A55853)
Ford Metal...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2019 Ford F-250 Super Duty Crew Cab (A55852)
2019 Ford F-250...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
