SERVIS Rhino Big Rhino rear blade
   / SERVIS Rhino Big Rhino rear blade #1
PaxMan
Member
West Central, IL
LS XR4145HC
Have any of you taken one apart and fixed the slop? Or is there some bolts that may need tightened? It痴 not terrible, but would like it a little tighter if possible.
   / SERVIS Rhino Big Rhino rear blade #2
When you say big, how big is what you consider big? Me, a 10 foot blade is big, A 10" blade is way big for your XR4145. Your tractor should handle an 8" blade well.
Typically there is no easy way to adjust for pin-sleeve wear that I am aware of.
Prior to RHINO actually becoming the branded name of Rhino, it was a company called Servis out of Texas. They made 3 blades. A Little Rhino, Big Rhino, and Super Rhino. The Alamo Group made this purchase in the mid 1980s
My blade is an 8ft blade.
   / SERVIS Rhino Big Rhino rear blade #4
Thanks for the clarification. Seems like it will be a good match for your tractor. Is the Bison blade just not enough? :confused:
   / SERVIS Rhino Big Rhino rear blade #5
So is mine. Have big Servis Rhino % little Rhino. Serious blades.Bought big one used 30 yrs ago. Heavy, heavy blade w/manual tilt, offset, angle & end caps. No toy. Bushings are sloppy in mine.
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2019 John Deere 85G Midi Excavator (A56857)
2019 John Deere...
Hose Reel (A55787)
Hose Reel (A55787)
2008 IC Corporation PB105 School Bus (A55973)
2008 IC...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
