Max 26xl and 28xl what to look for on used tractors?
   / Max 26xl and 28xl what to look for on used tractors? #1
monkeyman9
Member
Ford
Any common issues or problem areas I should be looking for in used max26xl and max28xl tractors?
   / Max 26xl and 28xl what to look for on used tractors? #2
I haven’t seen anything other than something about a starting issue. Maybe a hidden fuse or something.
This was more of knowing where the fuse is than anything else. Overall I hear good things about those models- probably a good choice.
   / Max 26xl and 28xl what to look for on used tractors? #3
Water/moisture can damage connectors in the wiring harness, causing a range of issues, including taking out the fuel solenoid, which will make the engine quit and/or fail to start.
Anything I can specifically look at for this? Connectors I should unplug and look for corrosion?
   / Max 26xl and 28xl what to look for on used tractors? #5
It may have been that fuel solenoid instead of a fuse.
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
BOMAG BW172D-2...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52128)
2015 Ottawa Yard...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2013 CATERPILLAR 320EL EXCAVATOR (A51242)
2013 CATERPILLAR...
19008 (A48082)
19008 (A48082)
