Re-sealed cav pump Ford 4500 racing
   / Re-sealed cav pump Ford 4500 racing #1
Dopi
Ford 4500
I just reinstalled a resealed cav pump I rebuilt on a Ford 4500 tractor. Tractor started up and ran fine once the intial air was all out and injector lines were tight. I restarted the tractor several times and observed for leaks for 5-10 minutes of running. I noticed nothing unusual other than low idle was about 150 rpm lower than it should be. I figured that would be an easy throttle stop adjustment I would make once I got the engine up to proper operating temperature. I worked at something else for a couple of hours and then returned to start the tractor again. Ran the tractor again for 5 minutes or so while playing with the throttle to see how the engine responded. All of a sudden the tractor raced to about 2000 rpm. Afraid of a runaway I immediately killed the engine. I restarted again a few times and had the same issue. I did not let the engine run at that speed for much more than a moment at a time.
What the heck is wrong now? I am pretty darn sure the governor linkage/springs are all correct. The throttle rod and lever all seem to be working normally.
   / Re-sealed cav pump Ford 4500 racing #2
I would reach out to thepumpguysc on here, you might even be able to send him a DM, he may be able to give you a few things to try before you pull all your hair out.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
Skid Steer (A52377)
Skid Steer (A52377)
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
