EZ drain valve for Deere 430
   / EZ drain valve for Deere 430 #1
jbradley
Clarinda, Iowa
JD 4020, JD 430 garden tractor, BCS 948, BCS 732
I'm wanting to replace the drain plug on my Deere 430 garden tractor with an EZ drain valve. Does anyone know the size and thread pitch? It's time for an oil change, so now's a good time to do a replacement.
Thanks.
   / EZ drain valve for Deere 430 #2
It is a metric thread I know because I brought a new one because mine was partially striped. You have to also know that there is a serial number break, the lower serial number ( - 004060) part (CH15382) runs around $3.79. The higher serial number (005001 - ) runs 3.79$ it's p/n CH19995. It is a common problem for the threads to strip. So do you have time to get the new drain valve with the tractor down to get the thread measured and to check the threads? It is what I had to do.
The serial number break is the engine serial number, mine is in the later serial number range.
   / EZ drain valve for Deere 430 #3
just wondering, how safe are those things to use. i would be afraid of it opening and draining oil out. not that familiar with them.
   / EZ drain valve for Deere 430 #4
It is totally dependent on the application and how protected (or not) the drain plug area is. I have them on 2 of my vehicles, but they are in a protected location above the plastic under-engine shroud. On a tractor, unless protected by a skid plate or a guard, I wouldn't risk it.
   / EZ drain valve for Deere 430 #5
I was going to install one. But the location of my drain plugs, on the tractor, is not totally protected. I passed and still use a box wrench.
   / EZ drain valve for Deere 430 #6
That area is where the drive shaft for the mower direct operates when attached. If your in tall grass the shaft could pick up an enlarge to break off the valve.
   / EZ drain valve for Deere 430 #8
My X738 came with one, Kawasaki V2, its like a petcock on a radiator, 2 qt capacity sump. Its a tight place to get at, had to buy a 10mm box ratchet wrench as you can only turn it 1/2 turn at a time to open/close. Has a 6-inch plastic tube on end to direct the flow down to a pan.
My 2010 X728 had same engine and same oil drain.
   / EZ drain valve for Deere 430 #9
Z71 Right, but it is likely not on the bottom side of the oil pan like I believe is the engine on the 430. Think that was the negative thought presented above.
   / EZ drain valve for Deere 430 #10
Its front of engine block, horizontal. Unless you put a 100 hrs a year on it, I would not be changing oil all to often. I usually use the best synthetic and change every 5 yrs (100 +- hrs). Some over maintain them with no discernible advantage.
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
FAKE (A52472)
FAKE (A52472)
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
