Daedong DK501 Three point linkage hydraulic shudder
   / Daedong DK501 Three point linkage hydraulic shudder #1
Cattle farmer
Daedong DK 50
I have had a problem with three point linkage shudders for a while it used to stop after a while but now it won't and it's so bad I have to wind down the hydraulic flow to stop the shudders and once it stops I can't lift the slasher. I changed the oil and filter when it started and it made no difference. Please can anyone give me advise. Thanks
   / Daedong DK501 Three point linkage hydraulic shudder #2
If you are getting a jerking type motion when pulling an implement it could be related to the position of the draft control lever, Or malfunction in the draft control.. It is designed to keep a constant pull load on the tractor by varying the height of the 3 point for ground engagement equipment. When it is activating it will give a jerking feeling.
Thanks for your comments Randy but I'm not pulling with the tractor just slashing or mowing the draft control makes no difference it's a strong up and down shuddering or jerking motion of the three point linkage that shakes the whole tractor. Thanks
   / Daedong DK501 Three point linkage hydraulic shudder #4
Could be the feed back linkage, if it slides on the rod just oil it. The piston seals leaking and/or o rings under the 3 PT control valve, that is all in the rockshaft.
Terex Loader Arm with Bucket (A51691)
Terex Loader Arm...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
