Steiner 430 max diesel swap
   / Steiner 430 max diesel swap #1
gunner27
Newmarket, Ontario canada
Steiner 430max
Hello I'm just in the process of buying a Steiner 430 max with the 27 gas air cooled motor ir runs a awsome and only has 1200 hours on it. I would like to switch it out for a Kubota diesel 902 or 1105 motor I was wondering if anyone has does this and if so can you please give me some info in what's in volved please? I know it will need a rad cooling far etc....and they should fit since they were a Factory option. Well the 902 was ( it may be called a 905) I can remember off hand. But any info would be awsome thanks. Iam a diesel and heavy equipment mechanic also so I would like to think I have a good idea on what I'm doing lol. Cheers Andrew from Canada
   / Steiner 430 max diesel swap #2
Good Morning Andrew: I am very interested in your progress with placing a 902 or 1105 diesel in your 430 max. I have a D722 in my 430 Max. And I am always asking the tractor for more than 18 hp can provide. Please let me know how this interest of yours progresses. Chaslaur@gmail.com
Bridgebum24
   / Steiner 430 max diesel swap #3
Bridgebum24
Skip the 1105 as it’s too long , unless you lengthen the chassis you won’t have room for the fan behind the radiator . The 902 shares the same external dimensions as the 722 so it should be a bolt on if you had a 430 diesel. I would sell yours and get a 430 diesel it’s too much money in parts to convert unless you have a parts machine .
   / Steiner 430 max diesel swap #4
Thank you for your reply concerning the diesel swap for my 430 Max. Because this tractor is a hobby I am investigating all of the changes that would be required to place a D1105-T-E3B where the D722 sits now. Yes the frame will have to be adjusted. The D722 already has the radiator and auxiliaries to support the D1105. I will have to have new sheet metal once the swap is completed. Thank you for your input.
Bridgebum24
Skip the 1105 as it痴 too long , unless you lengthen the chassis you won稚 have room for the fan behind the radiator . The 902 shares the same external dimensions as the 722 so it should be a bolt on if you had a 430 diesel. I would sell yours and get a 430 diesel it痴 too much money in parts to convert unless you have a parts machine .
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58216)
HYDRAULIC TILTING...
2017 GRAND DESIGN RV MOMENTUM (A58214)
2017 GRAND DESIGN...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
