L3130 Fuel Gauge
   / L3130 Fuel Gauge #1
Larry Caldwell
Super Member
Myrtle Creek, Oregon
Kubota l3130
The fuel gauge on my L3130 has quit working. It reads empty all the time. It looks like it shares a circuit with other gauges, which are working fine. Before I pull the sender, is it common to for a sender to go bad?
   / L3130 Fuel Gauge #2
yes, they DO go bad, sometimes the nichrome wire used for the resistor breaks, or the sender jams up mechanically. touching the sender wire to ground for a very short time will make the gauge needle move if it's good..
   / L3130 Fuel Gauge #3
The sender can be fine and still not work. There is a float which is supposed to move it. If the float sinks your tank will always read empty. Of course it could also be your gauge or a wire or connector anywhere in between.
   / L3130 Fuel Gauge #4
My L2501 is so inaccurate I might as well not have one. I just do it the old fashioned way - stick and eyeball.
   / L3130 Fuel Gauge #5
Replaced the sender years ago in the L3130, the connection to the ceramic resistor board (no ni-chrome on mine) was bad, corroded up by the water in the biodiesel here. Open hood pull pins and slide hood of the pins and remove sender, may be able to clean up, but probably replace.
David
   / L3130 Fuel Gauge #6
I guess a variable inductance transducer would last too long!.. they want to sell parts!..
   / L3130 Fuel Gauge #7
Pulled this sending unit out of the L3600 I'm servicing.....the ohm meter doesn't move when I test it.....
Looking for a new one....didn't see it in the parts on-line at Messicks. Any other ideas for sourcing one?
   / L3130 Fuel Gauge #8
It's not show in the Fuel section like one would think.
Check out the electrical system and B10301 SWITCH/SENSOR [EXCEPT CAB [CA] TYPE]
ASSY GAUGE, FUEL - ASSY UNIT FUEL T1060-31204 $100.61 1 in stock 1
Please confirm before ordering and hope this helps.
   / L3130 Fuel Gauge #9
Look under the Electrical section of the illustrated parts for the drawing: T04200 SWITCH
Two different sending units are shown depending on SN break.
160 GAUGE, FUEL ASSY - ASSY GAUGE FUEL 34070-31200 5-7 business days 1 S/N Break. Please Call
160.1 GAUGE, FUEL ASSY - replaces #34070-31200 TA040-31202 $119.55 1 in stock 1 to equal #34070-31200
160 GAUGE, FUEL ASSY - ASSY GAUGE FUEL TA040-31200 5-7 business days 1 S/N Break. Please Call
160.1 GAUGE,FUEL ASSY - replaces #TA040-31200 TA040-31202 $119.55 1 in stock 1 to equal #TA040-31200
170 GASKET - GASKET 34070-31220 $8.07 1 in stock 1
Please confirm PN's before purchaing.
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
