FEL CT335 Hydraulic hose ruptured
   / FEL CT335 Hydraulic hose ruptured #1
Omnipotent
As is said, the hose broke, part # is 7188081, Bobcat online parts catalog says item not available. Is there a replacement part or new part #? I tried looking at Kioti but couldn't figure out the correct cross-reference.
Any help is appreciated.
JD
   / FEL CT335 Hydraulic hose ruptured #2
rubber hyd hose or steel line ?
   / FEL CT335 Hydraulic hose ruptured #3
that is a steel line. I don't believe the Bobcat loader and Kioti loader are the same. They won't share that line. Any chance of welding it. What happened to it?
Might be right on the steel line, looking at the drawing again 7183002 might be the right part....it's the 4 rubber hoses that connect to the valve body.
Hose ruptured doing some grading work, wasn't too extreme, just burst when it was under load after a few hours of work. Tractor is 10 years old, so could be age.
   / FEL CT335 Hydraulic hose ruptured #5
If its the rubber hyd line you can take it to the hyd shop have new ones made OR the steel line to a welding shop....
Cool, thanks. Off to Napa I go.
Just to close this up, NAPA made a new hose, didn't have the wrap but that's OK, re-connected and back to normal.
Thanks again.
   / FEL CT335 Hydraulic hose ruptured #9
Great....:thumbsup:
2022 Cub Cadet Ultima ZT1 54in Zero Turn Mower (A55851)
2022 Cub Cadet...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
