M5640 Lower Link - Actual vs Messick's Diagram Picture ???
   / M5640 Lower Link - Actual vs Messick's Diagram Picture ??? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I bought a used M5640SUD Utility Tractor a couple years ago. I wish it had more adjustability in the 3ph. The previous owner told me he had the lower links switched over to the extension type for easier implement hook-up which was a Kubota change at Serial # 60,000. When I look at what is on the tractor compared to the Messicks diagrams there is a difference. Messicks shows for < S/N 60,000 3 holes in the lift rod and two holes in the lower link. I have only 2 holes in the lift rod and only one hole in the lower link.
If I look at the newer lower link it also has 2 holes.
So my question is - are Missick Diagrams generic illustrations or do they depict the actual part ??? And if they depict the actual part is there any way I can get dimensioned drawings so that I can compare to what I have and maybe modify it or get new parts ?? Thanks.
EDIT: FWIW my owners manual also shows 3 holes and 2 holes.
gg
Well I got one question answered. Messicks parts diagram is correct as you would expect. I found a picture on TractoHouse.com of a M5640 that clearly showed the 3ph and it had 2 holes in the lower link and 3 in the lift rod. Now if I could only find someone who has one of those maybe I could figure out what I have and how much the dimensions are different.
gg
   / M5640 Lower Link - Actual vs Messick's Diagram Picture ??? #3
Gordon, are you wanting to lift higher? :confused: Low 3pt implement lift height is a common problem with the under 85HP M series tractors. :(
Yes. The few times I have had a problem it was lack of height. This last time I remembered the previous owner said that he had had it switched over so I looked at the Messicks diagrams to see what was original. Don't know why mine are so limited in adjustment. I might just put another set of holes closer to the tractor in the lower links and/or get a second adjustable side link. A nice Fit-Rite hydraulic side link like I have on my L3010 would make it even better and that has been on my mind.
gg
   / M5640 Lower Link - Actual vs Messick's Diagram Picture ??? #5
Gordon
Have you checked to be sure the feedback rod is adjusted for maximum 3 pt rockshaft height?
   / M5640 Lower Link - Actual vs Messick's Diagram Picture ??? #6
Thats a great suggestion. I adjusted my m8540 and got 1.5-2" of extra height out of it in the height position. I usually have it in the heavy lift hole for hauling my 5th wheel around which sits at about 4000lbs of pin load
Gordon
Gordon
Thanks for the suggestion but yes - when fully raised there is very little travel left before it hits the stops.
gg
   / M5640 Lower Link - Actual vs Messick's Diagram Picture ??? #8
gg
Just like what's in the picture. ;) Something to keep in mind, I'm running about 20 weeks out for lead times. Either run them so that both the manual & hydraulic links are typically fully collapsed or splurge and get 2 hydraulic side links so that you have both left & right side tilt at your finger tips.
Or, just use a Hydraulic top link retracted to raise the tail end of the implement when needed. (most common solution)
Just something else to think about for an alternative. :thumbsup:
Hmmmm........... I already have the top link - came with the tractor. Biggest immediate obstacle is only one remote but 20 weeks would give me enough time to take care of that I would think.
gg
   / M5640 Lower Link - Actual vs Messick's Diagram Picture ??? #10
To overcome the lack of lift height of my M7060, I added to the bottom of my quick hitch for another set of holes. I believe they are 6" below the original. Works good on the 3-point
blade which would otherwise barley get off the ground in a level operation position.
New Holland TS6.130 4WD Utility Tractor with Slope Mower (A53421)
New Holland...
Ford Pickup NR (A50323)
Ford Pickup NR...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
RIGID 1224 HAMMER CHUCK MACHINE (A53843)
RIGID 1224 HAMMER...
