Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #12,354
Someone told me that glycol will keep a cookie from checking. It's not cheap though.
Polyethylene Glycol PEG Green Wood Stabilizer
It looks like Rockler's green wood sealer may be like the famous AnchorSeal, which runs about $30/gal.
Green Wood End Sealer - Select Option
I have not tried wax, and I have suggested it to some of my woodworker customers. Melt it and spread it where you want it. I ask them to report back on how well it works. No first-hand accounts yet. Anyone try wax personally?
I have tried latex-based elastomeric coatings without success.
   / Tractors and wood! Show your pics #12,355
I have heated up paraffin and turpentine half and half and brushed it on to keep wood from checking. Store the wood in a cool dark place for a year or two, good luck !
Did it work?
   / Tractors and wood! Show your pics #12,356
Yes, it works fine...
Paint sucks!
Anchorseal is expensive, but it's the best and easiest to use...
SR
   / Tractors and wood! Show your pics #12,358
A guy told me that also, he did chainsaw carving and soaked his bears in car ant ifreeze.
It is an interesting approach to the shrinkage problem. Instead of sealing the ends of the wood fibers with AnchorSeal or equivalent to slow drying, replace the water in the wood with antifreeze, which does not evaporate readily. Does the wood take on a greenish hue? Maybe not a big deal for darker species.
Maybe I will try that on the next cookie....
   / Tractors and wood! Show your pics #12,359
But how does it effect the way it takes a finish afterward?
   / Tractors and wood! Show your pics #12,360
I don't think that I would soak a piece of wood in antifreeze if I was going to make a table out of it. I have heard of people using it to rehydrate loose ax handles though.
Rooster Wooden Statue (A55853)
Rooster Wooden...
UNUSED FUTURE 350 HYD EXCAVATOR BREAKER HAMMER (A57193)
UNUSED FUTURE 350...
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55315)
2019 Krause...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
