TODAYS SEAT TIME
   / TODAYS SEAT TIME #10,901
Sometimes I think I have all the rocks and worse part is there all in the way............
   / TODAYS SEAT TIME #10,903
Oldpath, what are those daggers on the top corners of your bucket?
I mostly use them for just moving brush into a brush pile and for logs. Two 1/2" case hard bolts on each, I just get tied of the off and on for a little digging, seem so they work better for digging under rocks just dont work good for scooping dirt, I need retractable picks. I didn't think the rock was that big when I see it move so I could only flip the rock or push it which is all I needed.
   / TODAYS SEAT TIME #10,904
I'm referring to the daggers on the top corners.
   / TODAYS SEAT TIME #10,905
Brush hogged part of the hay field that was too wet to cut last season.
   / TODAYS SEAT TIME #10,908
I worked on some pressure washing and deck building. My M59 and man lift platform was high enough for most of the house except the chimney. I’ve got a 55 foot bucket truck but it’s got a busted gear box. Hopefully I’ll have the parts to fix it soon. IMG_8489.JPGIMG_8494.JPGIMG_8495.JPG
   / TODAYS SEAT TIME #10,909
UNUSED GRASSROOTS IMPLEMENT 5' SCRAPE BLADE (A57192)
UNUSED GRASSROOTS...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
