New-To-Me 790 -- Gear Question & Tips?
   / New-To-Me 790 -- Gear Question & Tips? #11
Hmmmmmm,, I am convinced that you are in high range,,
In low range, 1ST gear,, you could easily dismount, and walk circles around the traveling tractor,,
In low range, and even 2ND gear,,, you should be able to walk circles around the tractor,,
0.8 MPH is less than half a slow walk,, 1.1 MPH is about half of a walk speed, if you have an arthritic back,,
   / New-To-Me 790 -- Gear Question & Tips? #12
Agreed. I think you're in first gear of the high range. If you were in 1st gear of the low range, you would be less than one MPH. That's slower than molasses.
The H-L shift sometimes sticks on mine.
See, this is what I am thinking! So maybe I am not crazy?! I mean, I am the slowest human alive, but even I can outwalk 0.8 mph & I felt that an 18 yr old tractor should not give me whiplash in 2nd gear low. The H/L knob itself is definitely at the top of the shifty slot (that is absolutely the technical term for it, I'm sure). I wiggled it a bit, but didn't have time to fool with it too much. I will shift it around some more tomorrow -- if it is sticking in high, is "jiggle the handle harder" the best course of action or is there something else to check out?
Thanks very much for the helpful input!
ETA -- It appears in the manual that the top of the slot is supposed to L, although the diagram isn't as clear as it could be. Is that correct (I'm thinking of whether the knob might have gotten turned around so the labels are reversed, as I had happen on an old vehicle)?
   / New-To-Me 790 -- Gear Question & Tips? #14
Up is high range, down is low range... you're in high range.
We have a winner! I did confirm this afternoon in testing that the knob handle did indeed get twisted upside down so the labels were reversed, it's not stuck, & I am now able to bushhog at a speed that even a blind box turtle could outrun.
Thank you, everyone, for helping me figure this out.
   / New-To-Me 790 -- Gear Question & Tips? #16
:thumbsup: :thumbsup:
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
UNUSED FUTURE MINI EXCAVATOR RAKE (A57193)
UNUSED FUTURE MINI...
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2015 UTILITY VS2RA...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
