Posthole Digger Homemade post hole digger maintenance, PTO guard
   / Homemade post hole digger maintenance, PTO guard #1
ransonjd
Rochester, NY
BCS 605
I snagged a homemade post hole digger for $165 with an auger included. Is there anything that I should check before I run the thing?
Also, it doesn't have a PTO guard. Can I make a guard effectively and cheaply, or should I buy one?
   / Homemade post hole digger maintenance, PTO guard #2
On the auger gear box there will be plug for checking the fluid level. I would drain the fluid and replace it with 80/90w gear lube.
Also, check that the PTO shaft is the proper length. Make sure that the shaft doesn't bottom out or extend too far when attached to your tractor.
As for the PTO covers, that is for your safety. Many old pieces of equipment do not use them but, that is at the operators risk.
   / Homemade post hole digger maintenance, PTO guard #3
Gurus here like to see a photo before commenting...
   / Homemade post hole digger maintenance, PTO guard #4
Even NON- Gurus, like to see photos!!! As far as I'm concerned, NO one should be even remotely close enough to need a guard. Stay the <blank> away from it!!!! I removed my guard since I blew through a number of shear bolts and was tired of dealing with the guard to replace the bolts...
2013 Ford Escape (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
1973 Western Star Dump Truck (A51572)
1973 Western Star...
