Solar Battery Maintainer, AKA: Tender Recommendation
   / Solar Battery Maintainer, AKA: Tender Recommendation #1
Monster5601
Oakland, MI
Kubota B3030 R4 Tires
I am looking for a solar battery tender like device for the battery that runs my dump trailer's hydraulics. I spent a few hours looking at and reading the numerous offerings which is overwhelming. I'd appreciate recommendations from those that have used a solar maintainer for a year or more with good results. I don't want to waste money on a solution that isn't the best or doesn't have a reasonable life.
I do not have expectations of the solar unit recharging the battery after a day of dumping, the trailer has onboard charging for that. I'm looking to keep the battery at potential during the long time periods I do not use the trailer. The battery has a small parasitic draw from the wireless dump control unit. Really looking to mitigate this draw plus a few watts.
Thanks in advance.
   / Solar Battery Maintainer, AKA: Tender Recommendation #4
   / Solar Battery Maintainer, AKA: Tender Recommendation #5
Peter- Nice setup.
Mine is well ah a tad more primitive :embarrassed:
   / Solar Battery Maintainer, AKA: Tender Recommendation #6
I grabbed a couple of the solar chargers when my company did an upgrade to the GPS tracking units on semi trailers. I then added alligator clips and all was great! Then I forgot I had in on the tractor when I jumped on to mow a small patch of yard...and the mower made a slight modification to it that made it no longer adaptable to my use. I guess I need to hook up another one, but the first one did last more than a year!
   / Solar Battery Maintainer, AKA: Tender Recommendation #7
I just use a plug in cheapy Harbor Freight tender on both my RV battery and my riding mower battery. Not solar though, sorry.
How about just installing a battery disconnect switch to the battery terminal to stop the parasitic drain?
   / Solar Battery Maintainer, AKA: Tender Recommendation #9
I used the $5 HF cheapie charger and found it boils the water out if it is left on continually, even though they say it won't.
And I've tried the HF license-plate size solar charger. Then a second one. I'm not convinced those did anything at all.
I see Battery Minder, Battery Tender, and HF's equivalent all around $30. Anybody have comments on those? Can they stay attached indefinitely?
   / Solar Battery Maintainer, AKA: Tender Recommendation #10
I have connected a 10W Instapark panel to my lawn mower without a controller without a problem.i put another brand 10W panel on my backhoe and it seems to not help or hinder. Much larger battery.
I had a 100W panel on a deep cycle battery for my cameras with a cheap PDM regulator that worked until the regulator failed. I connected that panel direct and burned up the battery. $100 mistake.
I see now that Renogy has a waterproof controller. I will probably order one of those if I ever use my 100W panel again.
I had one of those HF panels laying around. Ii recently wired a usb socket to it and plugged a camera in to it. When it's getting light the camera reports that it's charging but the rate is slower than the consumption. Camera is still getting down to 15% in about 15 days.
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
