146 lift cylinder identification
   / 146 lift cylinder identification #1
loganhorse
Reynolds station ky
John deere 2440
My loader has no serial number to be located on it. I'm showing 2 different lift cylinders for that model. Without taking one a part and seeing what parts are needed is there anyway to figure out which kit I need?
   / 146 lift cylinder identification #2
Are the rod ends for each showing some difference? What I see on jdparts one is a square block end and the other is more of a pipe-like end.
Other than that, what two part numbers have you found? Like AW18444, and the other like AW25295 ?
   / 146 lift cylinder identification #3
Ditto I agree with been there.
Simple enough. I did not even notice the difference. I appreciate it.
Simpson 3600 PSI Pressure Washer (A57453)
Simpson 3600 PSI...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
SUV (A59231)
SUV (A59231)
Miscellaneous Wood Furniture with Glass Tops (A56860)
Miscellaneous Wood...
3 Tires and Rims (A57454)
3 Tires and Rims...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A57453)
2015 Freightliner...
