Tire Selection My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller)
   / My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller) #1
JohnnyAirtime
SAN DIEGO
Case 580CK, John Deere 240
Good day....
My current rear tires are 16.9x24
They have worn the paint off the rear backhoe outriggers/stabilizers (or whatever they're actually called).
I know the tires are pretty worn, and of course... one, is cracking.
If I buy new, in the same size I'm afraid they'll be even closer or more prone to contact the stabilizer.
Should I be looking at a little bit smaller (in diameter) tire? Since when new, it'll have more tread and therefore be a bigger issue.
... I might buy used also, so any help would be greatly appreciated. No need to put 'brand new' on Ol'Betsy when it's only used in dirt on my property.
Would the 14.9-24 be too small (too skinny)?
I have a lead on them, $250 each for used in really good shape. Better shape (deeper tread) then the 16.9-24.
HELP! ;)
   / My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller) #3
It looks like it came with 14.9-24 when new.......
   / My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller) #4
Both of my 68 580-ck's have 14.9 on them. You do not want 16.9 on them for any reason!--not good on tractor!
Thanks ALL!!!
I never thought to look at the specs. DOH!
..........You do not want 16.9 on them for any reason!--not good on tractor!
Why's that?
... they've been on there since I owned it.
Curious more than anything.
Time to make contact with the used seller with the 14.9-24s!!!
   / My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller) #6
I have had very good luck with Goodyear radials ..mind you size was 18.4 x 38, tad bigger ..
but very smooth under transport [rear duals] and better cleaning in the mud compared to Firestone bias ply
   / My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller) #7
Who ever put them on there had no respect for the tractor! Oversized tires on anything will put undue strain on the entire machine. ---Its like these **** kids with their big fat tires on their pickups---next thing transmission goes out---well duuuh!--what do they expect! ---same goes for tractors. Hard on clutches, transmissions, engines, axles. ---Its your tractor so put whatever you like on it.
   / My '67 CASE 580CK needs new rear tires. Help with sizing (to smaller) #8
^ Not to mention you lose power/torque with larger tires. All that can be made up with a re-gear on a normal vehicle, not so easy on a tractor.
(3) HAUL PRO DOLLY / CARTS (A54756)
(3) HAUL PRO DOLLY...
2022 CATERPILLAR 303CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2016 Hyundai Tucson (A53424)
2016 Hyundai...
2014 Ford Expedition (A55853)
2014 Ford...
10' CATTLE FEED THROUGH (A54756)
10' CATTLE FEED...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
