new member to mahindra forum
   / new member to mahindra forum #1
argyll
mahindra 3540pst
From argyll in Lockport,NY. Just purchased a 2015 3540pst. Trying to find out why the intake manifold heater light will not stay on. Tested the 60amp fuse and 1 inch square relay ,[no timer built in relay] and they tested good. wiring diagram does not show another relay in the circuit. Do they rely on the thermostat on the heater coil as the timer? Should I check the heater coil itself? Ordred a service and parts manual, but thought I would ask the forum to get a jump start on fixing it.
   / new member to mahindra forum #2
Why do you think it's broken? The intake heater should only come on when it's cold. Not sure if it's an external temp sensor or if it uses the thermostat, but either way - with the spring weather it shouldn't need it, and won't turn it on. Just checked mine, and the light will come on as part of the dash self-check, but goes off immediately after. It's 47 degrees here, it works correctly when it gets colder.
from Argyll, Thanks so much for the information. Makes sense. May be worrying about nothing. Very pleased with the tractor.
   / new member to mahindra forum #4
On my tractors, when the light goes off, its ready to crank.
I always use the heaters to crank after the engines have cooled down or cold from sitting.
2019 Chevrolet Tahoe 4X4 SUV (A59231)
2019 Chevrolet...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
FUEL CELL (A58214)
FUEL CELL (A58214)
