Best el cheapo pole saw...
   / Best el cheapo pole saw... #11
I also have a 15 year old Remington pole saw. Works great, still on the first chain. Never use it for anything but branches up in the air. 200 ft of extension cord works fine.
   / Best el cheapo pole saw... #12
<snip>looking for the cheapest saw that actually works OK...need about 8' reach the lighter the better...not going to be cutting anything bigger than 2.5"...
...Need it for about a 2 hour job that likely wont be needing done again for another 10 years...the 2 hours does not need to be continuous...
8 foot, 2 hours every 10 years?
Fiskars Brands-cutting P-Extendable Tree Pruner 7-12 Feet
Totally manual
https://www.walmart.com/ip/Fiskars-...MIyO_R3LDa6AIVhZ6fCh0NTAKUEAQYBCABEgJrrfD_BwE
   / Best el cheapo pole saw... #13
I also have an old Remington corded saw. I use a cheep HF 900w generator to power it. Works well
Last year bought the HF 40v chainsaw for light use. Been thinking about adding the pole saw.
But for a few branches, I have a manual pole saw. I think it was $40. Might be all you need.
When I said "elec." I should have clarified battery powered...I do not want to use a generator...
has no one used a 'Sun Joe' unit?
I also mentioned light weight as a criteria because deteriorated rotator cuffs in both shoulders are a handicap...(why a power saw is required)
   / Best el cheapo pole saw... #17
I've never heard of "Sun Joe" before, but see that Walmart carries that brand. They're probably as good as "Karcher" and I've got 2 of Karcher's pressure washers because on the 1st one the pressure switch failed and the pump would not shut off. So, for a few hours work I think it'll do, just be sure it includes a battery and charger. Some of the reviews say it came without.
   / Best el cheapo pole saw... #18
now if you could find a saw with the battery, preferably Lithium, separate from the saw, like on a belt clip or shoulder strap, that would make the saw much lighter!..
   / Best el cheapo pole saw... #19
/pine,
I saw a video somewhere of a guy who mounted a small gas saw on his FEL and trimmed branches that way. He had to do a lot of jockeying around but it worked. Might be worth a shot. I have shoulder problems too so I feel your pain. I can only trim for about 20 minutes at a time. Luckily I do not do much trimming.
Good luck.
   / Best el cheapo pole saw... #20
Any power saw will have a far heavier nose compared to a manual pole saw. These things need some force to swing the saw up to the limb. It might be easier on your shoulders to get a manual pole saw and do the project a few minutes per day.
Also most have a hook or slicer on the back side - but the ones used by professionals don't have that. The simple type - saw only - is lighter and won't get trapped where you have to rassle it to get it free. Avoiding getting the back side of the tool snarled up and stuck will avoid much shoulder stress.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2005 Texas Bragg T/A Gooseneck Trailer (A53117)
2005 Texas Bragg...
Freighliner Tender Truck (A53473)
Freighliner Tender...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
