Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #12,482
They have tons of brush and they get everything within a mile covered in sap. As for firewood valve it rots very quick and the heat value is a fraction of oak. I’ll take that log to the pallet mill and everything else from that tree will go to the burn pile. Then again I move tons of wood every year or if you want to be literal thousands of tons so I can be picky.
   / Tractors and wood! Show your pics #12,483
I guessed it was about a 4 X 4 and looked at a log weight calculator - a 4' diameter doug fir log 8' long weighs over 3800 lbs. And DF is fairly light. It looks like a good wt to me. Strong FEL on Kioti's. A lot more than my 30 hp L3010 can pick.
OK, the log. I calculated weight based on volume and the density, as you did. I have measured in years past weight loss from drying of over 35% for a DF log like this. But that was over 5y or so, and I use a scale that I hang from my bkt. The log in the above photo is still very wet.
As for lifting a 1500 or 1600# log, it is more about the weight of the tractor and counterweight (hoe attachment). With only a box scraper on the back, trying to lift something that heavy just tips the tractor. That is why I never take off my hoe (about 1400# or so with subframe). The most I have lifted with this tractor is about a ton (a pallet of ceramic tile), and only barely off the ground.
   / Tractors and wood! Show your pics #12,485
If you mashed on the throttle could you pull a wheelie with that log on the back? :)
With 5:10 gears in the rear end and that much stickoff probably so. You can definitely load a truck with logs until the front end is too light.
   / Tractors and wood! Show your pics #12,486
Why do you hate pines? 90% of what I cut is pine .
They are great if you're growing timber, but terrible near houses and roads. They shed limbs constantly, and the needles are a PITA.
   / Tractors and wood! Show your pics #12,487
Yeah, I am very small scale, just cut whatever I need. I don't burn much pine , most of mine goes into making lumber for around the place on my little mill. Everything around here is a pine plantation, mine was also before I bought it so I have mostly pine with a little hardwoods along my riparian corridor and the bottoms is all.
   / Tractors and wood! Show your pics #12,488
Agreed but its what I have. And yes needles are a pain!!
But they make GREAT construction lumber!!
   / Tractors and wood! Show your pics #12,489
Very true, I have about 40 acres of white pine that I manage for timber but the ones near the house are slowly [or quickly if its windy] coming down.
   / Tractors and wood! Show your pics #12,490
I have very few pines here, 1 giant one that is over 3' dbh, then the rest are scattered and nowhere close in size. The bulk of what I have is red oak, great for firewood but not so good for construction lumber. But I do have cedars, so I can at least Mill some siding, oh did I mention I really want to get a sawmill?
10 ft Shipping Container (A55973)
10 ft Shipping...
2021 Club Car Carryall 500 Electric Utility Cart (A55851)
2021 Club Car...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
JOHN DEERE PR84B 84" HYD POWER RAKE (A52707)
JOHN DEERE PR84B...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
