My Ford 445A is leaking Power steering oil BIGTIME
   / My Ford 445A is leaking Power steering oil BIGTIME #1
Off Road SHO
Cave Creek, AZ
1953 Ford Jubilee plus 4 other old Fords and 3 other newer Fords
It is leaking rather fast out of the bottom of the front axle housing, so I'm think the hose fittings have backed off up inside the axle housing. According to the manual, there's a T fitting for each function, steer left and steer right. The T fittings go up though a plate that is bolted to the bottom of the housing. We've removed the nuts on the two studs that attach the plate to the bottom, but the plate will not budge. I'm wondering if that plate is tapped those two studs thread through the plate and into welded on nuts up top.
Anybody familiar with that hose arrangement?
TIA
Tom
   / My Ford 445A is leaking Power steering oil BIGTIME #2
TIA
Tom
No Ford 445A listed in your profile.
No geographic location either.
Ok I fixed that. I didn't know ALL my tractors needed to be in my Profile. Besides the 445A that is leaking, I also have a 260 and a 4000SU.
Tom
   / My Ford 445A is leaking Power steering oil BIGTIME #4
Tom
NONE of your tractors NEED to be in your profile.
It does give a more complete picture of your situation though.
See....now we know that you are a Ford guy, and being a Ford guy is a very good thing.
Unless you have a tractor buying sickness like I do.
   / My Ford 445A is leaking Power steering oil BIGTIME #6
TIA
Tom
I assume you solved this issue? I have the same problem with my ‘83 445A. Dripping from area where the pressure lines go through the large rubber grommet.
Bill
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52141)
2020 INTERNATIONAL...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
71054 (A49346)
71054 (A49346)
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
